Accidentally I was reading the same article yesterday - anybody knows more details about bispheric double reflecting condenser ? Why it is so special ?
Diameter of black disc for darkfield?
It's just one of the many types developed over the years and shown in this pdf. I don't know why it would be special, though it seems to resemble the basic working principal of the leitz heine condenser but at a hgher .na and specifically for darkfield.Saul wrote:Accidentally I was reading the same article yesterday - anybody knows more details about bispheric double reflecting condenser ? Why it is so special ?
http://www.med.unc.edu/microscopy/files ... dark-field
Thanks ! I read that also Is this reflection ball is movable ?GaryB wrote: It's just one of the many types developed over the years and shown in this pdf. I don't know why it would be special, though it seems to resemble the basic working principal of the leitz heine condenser but at a hgher .na and specifically for darkfield.
Saul
μ-stuff
μ-stuff
No, they're all fixed as far as I've been able to determine. A movable dome would certainly be a great step forward, though I think it would need to be a parabaloid shape rather than dome, same with the reflector for true versatility. I would love to see that made. Even just molded/machined acrylic with some chrome plating would be a good start as a prototype... *hint to any designer types out there*
Started already.... but need community help.GaryB wrote:No, they're all fixed as far as I've been able to determine. A movable dome would certainly be a great step forward, though I think it would need to be a parabaloid shape rather than dome, same with the reflector for true versatility. I would love to see that made. Even just molded/machined acrylic with some chrome plating would be a good start as a prototype... *hint to any designer types out there*
https://www.3dvieweronline.com/members/ ... S6UtuA9lyP
Dome will be movable. Another question - picture from the Olympus website says that it is from solid glass . What - all shell or base filled filled with solid glass ? If it is 2nd option - is this surface reflective ?
Saul
μ-stuff
μ-stuff
Hi Saul
I hope this post might be of some help.
There is a mention of a "Bispeheric Double Reflecting design" referencing a Reichert immersion high NA DF condenser on the "Microscopy as a hobby......" Yahoo Group.
https://groups.yahoo.com/neo/groups/Mic ... pics/71129
There is a link to a photo album.
http://groups.yahoo.com/group/Microscop ... 9/pic/list
Also I have found an Ebay item with photos to view assuming that this is the same Reichert design.
https://www.ebay.com/itm/302680002061?V ... 2680002061
HTH
BR
John
HTH
BR
John
I don't, but I will happily join a group buy, if you or anyone makes such an adjustable rosette / reversed iris. I prefer more leaflets to make a relatively smooth circle, if possible.ChrisR wrote:Does anyone have a pattern for a set of "petals" to make one of the adjustable "rose" stops?
I could get one (or more) laser cut. Not from metal though, afaik.
I am interested in Saul's condenser lens too and can compare it to my Leitz Heine. I am moving though (and microscopy items are boxed up), so it will take a month or two, if my comparison report is needed.
I will dig out my version of this, sometime today and offer up some measurements.
Many condenser diaphragms use brass pins at each end of the leaves, to actuate the motion of the leaves. Some have the pins set into the leaves but some have the pin set in the outer ring and the leaf has a hole in it that rotates about the pin. An old condenser , either with or without fixed pins, because they could be pressed out, would serve to provide leaves for a variable DF stop. The leaf ends could be stacked on a central shaft. Shaping would take a bit of fiddling but they can be cut to size easily.
One might even be able to adapt an old iris diaphragm housing to the task.
I've dreamt up a way to make an expanding "circle", but I'm sure someone did it better a long time ago.. What range of diameters would be needed?
Depends on the condenser height?
I'm not sure of the resolution of the laser cutter. I know it won't cut metal, but probably would do something suitable. Any suggestions? "Delrin"?
Res of the most accurate 3D printer I have access to is 20µm.
