www.photomacrography.net :: View topic - Aphid Identification
glmory
PostPosted: Tue Mar 06, 2018 10:25 pm    Post subject: Aphid Identification Reply with quote
I have been working quite a bit of macro and micro photography into my iNaturalist observations this past year.
When I started photographing aphids, the experts I talked to didn't think more obscure species could be identified from photos. As I learned more, I saw their point. However if you work through a key, photographing every feature in the key it is usually possible to do. You just need photos of the right features with the right measurements.
Here is an aphid I have yet to get to species conclusively(https://www.inaturalist.org/observations/10072629). It is either Chaitophorus utahensis or a similar but undescribed species in that genus.
I start with macro photos of the aphids:
Then I slide mount them and take an overall photo using an Amscope 4x objective. On that I take a bunch of measurements which I know are commonly required to work through keys:
Then I go through a key taking photos of other characteristics which are needed to make it to an identification. When I need good quality I use a Nikon E Plan PH3 40x objective
It is on a Labophot microscope with brightfield dark field and phase contrast. I was too cheap for a trinocular head so I just put a dovetail adapter and a bunch of extension tubes on it.
[/img]
All the photos are taken with an a6300 camera. I put it in silent shutter mode on the camera app, then have continuously take photos while I move the focus.
I stack in Zerene Stacker then add scale bars and clean up the background in Photoshop.
clengman
PostPosted: Wed Mar 07, 2018 10:36 am    Post subject: Reply with quote
Very nice! What method do you use for preparing your aphids for TL? Are you making permanent mounts?
glmory
PostPosted: Wed Mar 07, 2018 12:59 pm    Post subject: Canada balsam Reply with quote
Yeah, they are permanently mounted. I learned to make mounts in Canada Balsam by watching some online videos.
Here is a description of the procedure:
https://www.inaturalist.org/journal/glmory/11320-aphid-identification-ii
