www.photomacrography.net :: View topic - Butterfly scales as close as I can get with my rig
PostPosted: Tue Feb 27, 2018 12:37 pm    Post subject: Butterfly scales as close as I can get with my rig Reply with quote
Butterfly wing scales by Waldo Nell, on Flickr
Butterfly wing scales, 100x, DIC
PostPosted: Tue Feb 27, 2018 12:50 pm    Post subject: Reply with quote
That's impressive! Stuck to the underside of a coverslip?
What objective is that, Waldo?
PostPosted: Tue Feb 27, 2018 12:56 pm    Post subject: Reply with quote
Well, between the slide and a coverslip yes. I did use a small trick - I did not use water between the slip and slide, I used immersion oil. That worked better with the scales as these scales are hydrophobic.
It is the Olympus UPLSAPO100XO;U PLAN S-APO 100X OIL OBJ, NA 1.40 and of course the oil condenser.
kit1980
PostPosted: Tue Feb 27, 2018 5:56 pm    Post subject: Reply with quote
Very nice!
Thanks for mentioning your oil "trick".
Omax microscope with Nikon CF objectives
Olympus OM-D E-M10 Mark II camera
http://sdymphoto.com/
PostPosted: Tue Feb 27, 2018 6:20 pm    Post subject: Reply with quote
Wow, these are lovely. Not only a technical masterpiece but also very artistic.
www.loujost.com
billben74
PostPosted: Fri Mar 02, 2018 2:35 pm    Post subject: Reply with quote
Very sharp and beautiful images
PostPosted: Fri Mar 02, 2018 3:13 pm    Post subject: Reply with quote
Thanks for looking.
PostPosted: Sat Mar 03, 2018 8:01 am    Post subject: Reply with quote
Excellent. The detail in the first and last shots is exceptional for a conventional light microscope.
