I found trying to image the nucleus very challenging as it's deep inside the cell and often masked by the chloroplasts. Focus stacked, 40x S-Plan APO DIC flash
Spyrogyra nucleus
Spyrogyra nucleus
Linden Gledhill http://www.flickr.com/photos/13084997@N03/
Hi Rik, what would be the minimum number of steps i would need to render the stereo view
There's no hard-and-fast number. I've seen good results from 20-ish frames. More important is the physical aspect ratio of the subject, depth:width. As that drops below 1:10 or so, the depth gets harder and harder to see.Linden.g wrote:what would be the minimum number of steps i would need to render the stereo view
Use the formulas at https://zerenesystems.com/cms/stacker/d ... wing_angle to calculate what shift % you need, based on your subject dimensions and viewing angles.
Thanks for the additional information on viewing angle and step estimation Rik. I need to have another go at imaging the nucleus.
