www.photomacrography.net :: View topic - 1999 AMI Wafer
1999 AMI Wafer
Goto page 1, 2, 3  Next
Smokedaddy
PostPosted: Wed Feb 21, 2018 10:31 pm    Post subject: 1999 AMI Wafer Reply with quote
Yet another different wafer. I think the BW are interesting. Can't wait to do a nice panorama.
-JW:
Smokedaddy
PostPosted: Thu Feb 22, 2018 2:19 pm    Post subject: Reply with quote
Here's a quick video of the 1999 5" AMI Idaho Wafer at 40x with a Mirau Interferometer objective on a Nikon MM-11 with universal epi illuminator using bright field.
https://www.youtube.com/watch?v=MJ-ke9Y0dB0
-JW:
Saul
PostPosted: Thu Feb 22, 2018 2:40 pm    Post subject: Reply with quote
3rd is impressive
Saul
Olympusman
PostPosted: Fri Feb 23, 2018 2:04 pm    Post subject: Microprocessor Reply with quote
Lovely images.
Smokedaddy
PostPosted: Fri Feb 23, 2018 7:23 pm    Post subject: Reply with quote
... thanks.
Smokedaddy
PostPosted: Sat Feb 24, 2018 1:51 am    Post subject: Reply with quote
Smokedaddy
PostPosted: Sun Feb 25, 2018 12:27 pm    Post subject: Reply with quote
Thought I'd try a stereo image with Zerene. I struggled with this particular stereo image subject but Rik had the patience to work it out with me. I'm not stupid but sometimes procedures and terminology simply aren't clear to me. I thought it turned out pretty well considering the subject.
-JW:
Saul
PostPosted: Sun Feb 25, 2018 1:33 pm    Post subject: Reply with quote
Smokedaddy wrote:
...it turned out pretty well considering the subject...
Fully agree. Nice stereo
Saul
PostPosted: Sun Feb 25, 2018 3:02 pm    Post subject: Reply with quote
Challenging subject, nice result!
This one is entirely JW's work, by the way. The one I helped him with was a completely different stack.
I do wonder whether this is intended to be cross-eyed or parallel. It looks more "natural" to me if viewed parallel. That puts the big contact pads in front of the other structures, versus pads behind when viewed cross-eyed.
Smokedaddy
PostPosted: Sun Feb 25, 2018 4:05 pm    Post subject: Reply with quote
My intent was only viewing with my Berezin Pocket 3Dvu glasses.
Smokedaddy
PostPosted: Sun Feb 25, 2018 4:41 pm    Post subject: Reply with quote
I shot this one with a green filter and converted it to BW. This turned out excellent 3D wise with my Pocket 3Duv glasses. Lot's of dept and layers are visible. Probably at least 6 layers .. very cool. Same camera 50D with 2.5x relay lens and a Nikon BD Plan APO 100/0.90. Only a 9 image stack.
-JW:
PostPosted: Sun Feb 25, 2018 8:59 pm    Post subject: Reply with quote
Those are nice little tools, aren't they?
They give what I've called "parallel" view, with each eye seeing the image on its same side.
That's beautiful! Much less obvious artifacts than the full-color version.
Smokedaddy
PostPosted: Sun Feb 25, 2018 9:01 pm    Post subject: Reply with quote
Thanks ... I really like the monochrome stereo image.
Smokedaddy
PostPosted: Mon Feb 26, 2018 9:11 am    Post subject: Reply with quote
Here's the same one with the green filter.
-JW:
PostPosted: Mon Feb 26, 2018 11:11 am    Post subject: Reply with quote
Adding some technical information about the stereo...
JW tells me that the image is not cropped, but in addition to the 100X objective there was a 2.5X relay lens.
So then I work the numbers like this...
Depth is about 3 microns (9 frames @ 1/3 micron per frame)
Width is nominally 89.2 microns (22.3 mm sensor width, divided by 250X total optical magnification (=100*2.5))
-2% corresponds to view angle about -30.7 degrees. (Crosscheck using the formulas at zerenesystems.com: TAN(RADIANS(-30.7)) * (3/89.2) * 100 = -1.997)
+4% corresponds to view angle about 49.9 degrees. (Crosscheck: TAN(RADIANS(49.9)) * (3/89.2) * 100 = 3.994)
Total viewing angle is 80.7 degrees (=49.9+30.7, rounded from extra digits not shown) .
Typical max viewing angle in real life is only about 8-10 degrees (10 degrees = 2.5 inches between eyes, 14" viewing distance), so the stereo pair is exaggerating depth by about 10X. If you were able to look at something this small through a real stereo microscope, it would look a lot more flat.
Looking again this morning, I'm still really pleased by the gray-scale pair. Nice job, JW!
Page 1 of 3
