www.photomacrography.net :: View topic - Oshiro 60mm 2:1 vs. Laowa Venus 60mm 2:1
tomek770101
PostPosted: Wed Feb 21, 2018 9:40 am    Post subject: Oshiro 60mm 2:1 vs. Laowa Venus 60mm 2:1 Reply with quote
hello all,
Can someone compare these two lenses? best by pictures in 100% resolution. in the center and on the corners. Is the difference between them in the quality of photos?
PostPosted: Wed Feb 21, 2018 11:12 am    Post subject: Reply with quote
Read all about it! Here>
http://www.photomacrography.net/forum/viewtopic.php?t=34773
enricosavazzi
PostPosted: Wed Feb 21, 2018 11:54 am    Post subject: Re: Oshiro 60mm 2:1 vs. Laowa Venus 60mm 2:1 Reply with quote
tomek770101 wrote:
hello all,
I am actually slowly doing this comparison, on and off. Don't hold your breath.
I made and even wrote up a comparison before, but the 1951 USAF resolution target I was using turned out to be too bad to give informative results ( http://www.savazzi.net/photography/1951usaf.html ), so I decided to do it all over again.
However, so far, the verdict is: no significant difference in image quality.
PostPosted: Wed Feb 21, 2018 12:03 pm    Post subject: Reply with quote
See also http://savazzi.net/photography/laowa-oshiro-test.html and http://savazzi.net/photography/60mm2x_lenses.html , which makes clear that the two lenses are in fact easily distinguishable, with different coatings and optical formulas. Definitely not clones.
myxomop
PostPosted: Wed Jun 27, 2018 2:52 pm    Post subject: Reply with quote
thanks for your in depth comparisons, enricosavazzi. I'm intrigued by this lens as well. Laowa, on the other hand, is apparently quite pissed off about it:
[/img]
MACRO:
Canon 6D, Canon MP-E 65mm Macro Lens, Sigma 50mm f/2.8 EX DG Macro, Amazon.com : YongNuo YN-14EX TTL Macro Ring Lite Flash, Laowa/Venus Optics KX-800 Flexible Macro Twin Flash, Gitzo GT2540EX Tripod, Acratech GV2 Ballhead
MICRO:
Trinocular Olympus BHS, SPlan 4x, 10x, 20x, 40x (1.25 N.A.), SPlanApo 100x Oil (1.4 N.A.), BH2-AAC Aplanatic-Achromatic 1.4 N.A Brightfield Condenser, WHK 10x 20 L Eyepieces, NFK 2.5× LD 125 Photo Eyepiece, Diagnostic Instruments PA1-10A SLR Camera Adapter
