www.photomacrography.net :: View topic - Will these strobes work?
Deanimator
PostPosted: Tue Feb 20, 2018 7:48 pm    Post subject: Will these strobes work? Reply with quote
Having just gotten my first real job in nine years, I've got some more money to invest.
Would these strobes be appropriate for macrophotography, particularly with the Amscope 4x and 10x objectives?
I suspect that I might have to use light stands (which I already have) instead of magic arms for these.
https://www.adorama.com/fp320m.html
PostPosted: Tue Feb 20, 2018 9:51 pm    Post subject: Reply with quote
I have these 320M, they are good for macro use, but very old design.
However the better value IMO is the Studio Strobe 300 AC (have these also) which is 300WS and has a built in RF receiver, 320M has 150WS and no RF Receiver. Also the 320M has an Adorama specific mount while the Studio 300 has a universal Bowens mount (better light modifiers options). The Studio has a uniformity output spec of 2%, whereas the 320M has none.
I'm in process of upgrading to the Studio 300 AC as my "go to" macro strobes.
Any of these strobes are much too heavy for anything but a very sturdy light stand or C stand (has an arm which allows direct placement of strobe near subject at just about any position). With the C stand I can hang my strobes around subject almost as easily as I could a speed light.
~Mike
Deanimator
PostPosted: Wed Feb 21, 2018 4:45 am    Post subject: Reply with quote
Thanks. That's very useful information.
The price is certainly right.
Deanimator
PostPosted: Sat Mar 10, 2018 1:27 am    Post subject: Reply with quote
I was waiting for my first paycheck from the new job to get a couple of the units you recommended. Just my luck, they're out of stock at Adorama right now.
So instead I bought an Adorama R2 trigger/receiver set and another 11" Neewer magic arm from Amazon. I can use this stuff for my field rig to replace the ETTL cable which gets in the way. When the strobes are back in stock, I can use the trigger for them.
PostPosted: Sat Mar 10, 2018 5:57 am    Post subject: Reply with quote
Earlier they (300) were priced a $99 as a special, $20 off. You don't need the R2 receiver with the 300, it's built-in.
BTW one thing I forgot to mention about the 320M is that it can be battery powered, the 300 doesn't have this capability, only AC power.
~Mike
Deanimator
PostPosted: Sat Mar 10, 2018 8:30 pm    Post subject: Reply with quote
They come as a set. As noted, I can use the receiver for the Sigma flash on my field rig. When the strobes are back in stock, I can use the transmitter for them as well as the Sigma.
The strobes will only be used in my living room, so battery capability is nice but unneeded.
dolmadis
PostPosted: Sat Mar 10, 2018 11:05 pm    Post subject: Reply with quote
Hi
I am in the UK and even when in stock in the USA the shipping costs are too high.
I found this item.
https://www.ebay.co.uk/itm/Godox-Smart-300SDI-300W-Mini-Studio-Strobe-Flash-Lamp-Head-AC-01B-Trigger-220V/222860169908?epid=1639625797&hash=item33e38052b4:g:DpAAAOSwZ1Falo0X
Is it in the same clone series?
Thanks
John
Deanimator
PostPosted: Sun Mar 11, 2018 12:44 am    Post subject: Reply with quote
dolmadis wrote:
Hi
I found this item.
Thanks
John
Flashpoint is Adorama rebranded Godox.
I think it's at least similar to the picture I posted.
RobertOToole
PostPosted: Sun Mar 11, 2018 2:03 am    Post subject: Reply with quote
Deanimator,
I use 4 of the smallest godox flash wireless units, the TT350. I normally only use 2 and get away with 1/32 to 1/4 power with 2 layer of diffusion at ISO 100.
Those studio strobes look like they really tough to position to light the subject?
What am I missing?
Are you lighting a huge area or a group of people?
Deanimator
PostPosted: Sun Mar 11, 2018 2:24 am    Post subject: Reply with quote
RobertOToole wrote:
Deanimator,
What am I missing?
No, just tabletop macro subjects.
They're definitely harder to position than the manual speedlights I use, but much more consistent, and I wouldn't have to worry about batteries.
PostPosted: Sun Mar 11, 2018 5:45 am    Post subject: Reply with quote
RobertOToole wrote:
Deanimator,
What am I missing?
Robert,
It's actually really easy to place if you use a studio "C" stands like I use. You can position the strobes just about anywhere and they can rotate out of the way when fiddling with things.
Moved away from speedlights over 10 years ago, got tired of dealing with batteries, chargers, long recycle time, inconsistent outputs, overheating & melted heads and so on. Of course I'm abusing them by asking for up to 1000 repeated flashes, with only a few seconds between, then a few minutes rest and doing it all over again, so brutal use! I've even had 3 cheap Neewer strobes actually explode, the energy storage capacitors would fail and explode. When I went to the Adorama strobes thing got much better, the Studio 300 AC is the best value IMO, and a great workhorse for macro work with built in RF trigger and control for ~$120. I have 4 and plan on replacing my other 5~6 strobes with them.
~Mike
