www.photomacrography.net :: View topic - Epi lighting using a Nikon UM-2 Measurescope
Goto page 1, 2  Next
PostPosted: Tue Feb 13, 2018 3:36 pm    Post subject: Epi lighting using a Nikon UM-2 Measurescope Reply with quote
Posts split from thread at Scalpel vs double-edge razor
Smokedaddy wrote:
Here's the Feather blade at 40x. It's a PMAX stack. I'm not sure what the somewhat blurry areas are or IF it's just how it is. Haven't done the scalpel blade yet.
At a tangent - how did you light the last image, with the 40x NA 0.80?
Only 0.8mm WD iirc. I assume you used epi-lighting?
Smokedaddy
PostPosted: Tue Feb 13, 2018 3:48 pm    Post subject: Reply with quote
Yes ...
-JW:
PostPosted: Tue Feb 13, 2018 4:24 pm    Post subject: Reply with quote
Please excuse the continuation of the tangent Very Happy
I have the same parts, up to the top of the cream colored Trinoc tube.
Could you tell me what parts are not visible within, and above, please?
You have some photo eyepiece in there I assume, and the black tube - ?
thanks
Smokedaddy
PostPosted: Tue Feb 13, 2018 5:50 pm    Post subject: Reply with quote
Sure, the black tube is a Nikon microscope photo tube adapter PA01-12A with a Canon T-mount adapter. It has one of those 2.5x photo eyepieces in the trinocular tube. I don't normally use that setup. Meaning the tube and photo relay eyepiece but usually do with the MM-11 when using the EPI setup. I would think that the tube could easily be 3D printed or machines. They want a arm and a leg for one of those puppies. I found one on eBay for a fraction of the price of a new one so I bought it. The T-mount adapter doesn't fit like it should and I haven't looked into way yet since I rarely have used it.
-JW:h
Smokedaddy
PostPosted: Tue Feb 13, 2018 7:09 pm    Post subject: Reply with quote
PostPosted: Tue Feb 13, 2018 7:17 pm    Post subject: Reply with quote
Thanks
The black part's just a plain tube, with no optics?
Smokedaddy
PostPosted: Tue Feb 13, 2018 7:37 pm    Post subject: Reply with quote
ChrisR wrote:
Thanks
No optics.
https://webstore.diaginc.com/PA1-12A-35mm-SLR-Camera-Adapter-for-Nikon-Microsco-p/wsn-pa1-12a.htm
-JW:
PostPosted: Tue Feb 13, 2018 9:09 pm    Post subject: Reply with quote
$269.00 and it's not even flocked!
Thanks, I have some plumbing which can go on there.
Smokedaddy
PostPosted: Tue Feb 13, 2018 9:21 pm    Post subject: Reply with quote
I wouldn't pay that either, nor even 2/3rd's that. <g>
genera
PostPosted: Tue Feb 13, 2018 10:43 pm    Post subject: Reply with quote
Here's a cheaper alternative if you're using a Nikon camera (see the 2nd Photo):
https://www.ebay.com/itm/Nikon-UFX-DX-Laboratory-Microscope-Attachment-FX-35DX-Camera-Housing-Unit/152889301379?hash=item2398e99983:g:3fAAAOSwVVRacowe
The UFX-II body + adapter "A" together are the same length as the DI PA1-12A plus T-MNT adapter. The bottom diameters are the same too so it can be used in place of the PA1-12A.
I posted here a year ago on how to move the UFX internal optics out of the way and open the shutter with a battery and jumper wires. Here's the link if decide to try it.
https://www.photomacrography.net/forum/viewtopic.php?t=15806&postdays=0&postorder=asc&highlight=nikon+diagnostic&start=15
-Gene
PostPosted: Wed Feb 14, 2018 9:32 am    Post subject: Reply with quote
Thanks Gene
That looked attractive at $20 until I saw the shipping is $67 even to the US, and I'm in the UK.
There seem to be a lot of similar-looking Nikon contraptions about; I assume that's the only one with the relevant features and fittings?
Smokedaddy
PostPosted: Wed Feb 14, 2018 11:10 am    Post subject: Reply with quote
Just for clarification my pictured Frankinscope is a MM-11. I know they are similar. I wonder if the 'internal' focus gearing components are the same on the UM-2 is the same as a MM-11.
I still think it would be super simple to 3D print a tube 'exactly' as the one I posted and glue the proper camera adapter on one end.
A while back I 3D printed a Nikon MM-11 dovetail by 30.5 Tiffen filter adapter, see image below, just to see if it worked and for no particular reason. It's a Ttiffen 30.5 UV filter (number 2) that I took the glass out of, then glued it onto the 3D printed adapter (number 1). Then I reverse and screw my 28mm Schneider Kreuznach Componon on the end of it as shown below. Of course I can always redesign the 3D printed PLA adapter to make it shorter to some degree or longer.
-JW:
Smokedaddy
PostPosted: Wed Feb 14, 2018 12:10 pm    Post subject: Reply with quote
BTW, I don't have a manual for the UM-2, only the UM-11U and UM-22U so I couldn't verify the focus components compatibility (not that it matters).
genera
PostPosted: Wed Feb 14, 2018 1:32 pm    Post subject: Reply with quote
ChrisR wrote:
Thanks Gene
You must be seeing UK shipping. It's $28 to me in the US.
The Nikon AFX-II microscope camera is functionally identical in the critical areas so it will also work. The PFX may work but I haven't examined one.
Here's another UFX. It's an auction style listing with the bid currently at $25 plus $33 shipping to the UK, plus $10 import charges (based on the current bid amount):
https://www.ebay.com/itm/Nikon-Microscope-FX-35DX-Camera-UFX-DX-Adapter/162902361164?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D49917%26meid%3D90e744c6da1e461ea230e6b9f1a2517e%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D152889301379%26itm%3D162902361164&_trksid=p2047675.c100005.m1851#shpCntId
Nikon also makes a tube called the "F Mount Photo Adapter". It's functionally equal to a PA1-12A that has a F mount adapter attached. They don't have any markings so no one knows what to call them, making them somewhat difficult to find.
Here's a look at one:
https://www.ebay.com/itm/Nikon-Microscope-SLR-DSLR-Camera-Photo-Adapter-Tube-Original/302628635931?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D49917%26meid%3Dcd9ca80b302c430f9656f8712709e48a%26pid%3D100005%26rk%3D6%26rkt%3D6%26sd%3D292449778950%26itm%3D302628635931&_trksid=p2047675.c100005.m1851
None of these are complete solutions, even the PA1-12A. You still need an adapter tube between it and the trinocular port as well as a relay lens.
-Gene
PostPosted: Thu Feb 15, 2018 8:33 am    Post subject: Reply with quote
Genera wrote:
You still need an adapter tube between it and the trinocular port ....
Oh, I didn't realise that.
What's supposed to go between the shutter unit and the trinoc tube?
I have some tubes with M42 at the top which slide in to the trinoc port well enough that I should be able, maybe some tape, get it central and grip with the thumbscrew.
The shutter appeals, for clattery Nikon cameras without EFSC.
(Shipping varies all over the place. The $67 was to a different US State, and the "estimates" to the UK are never right!)
Goto page 1, 2  Next
Page 1 of 2
