www.photomacrography.net :: View topic - Fungal Spores
Fungal Spores
micro_pix
PostPosted: Fri Feb 02, 2018 4:15 pm    Post subject: Fungal Spores Reply with quote
Here are some photos of fungal spores and the basidiocarps that produced them.
They are all taken under the 100X oil objective (with the exception of the Entoloma which was 40x). They vary in size but are between 7 and 18 microns in length. The first four are from the same genus.
The spores are as photographed, the background has been cleaned and I thought they looked better with a slight shadow which I added in Photoshop.
Panaeolus semiovatus
Panaeolus acuminatus
Panaeolus fimicola
Panaeolus papilionaceus
Hypholoma ericaeum
Inocybe stellatospora
PostPosted: Fri Feb 02, 2018 10:47 pm    Post subject: Reply with quote
Wonderful! Very effective to see field shots of the fruiting bodies juxtaposed with the spores as you have done. And to have four species of the Panaeolus genus placed so neatly for comparison. Very Happy
Did you treat any of those spores with KOH?
micro_pix
PostPosted: Sat Feb 03, 2018 2:12 am    Post subject: Reply with quote
Thanks Chris. No I didn’t use KOH with these, they were in water. The Panaeolus spores are all naturally dark, the spore print is what I’d calll black/brown, and the Hypholoma and Inocybe spores are mid brown.
I always try and avoid using KOH on fresh spores as I get a better record of their natural colour through the scope but you do need good resolution (or DIC) to see the hyaline spores easily. I have often used lacto-phenol cotton blue if I’m looking for surface ornamentation on the spores but if you have it, DIC is great for that too.
Pitufo
PostPosted: Sat Feb 03, 2018 3:36 am    Post subject: Reply with quote
Very nice work and good to have photographs of the spores. This group can be hard to tell apart and spore descriptions are not nearly as helpful.
I didn't realise that KOH had an effect on the colour of spores but it can change their size slightly I believe.
micro_pix
PostPosted: Sat Feb 03, 2018 4:13 am    Post subject: Reply with quote
Thanks Pitufo. It’s a long time since I looked at spores in KOH as I invariably look at fresh spores in water. I thought I remember that it made the spores appear a bit darker/browner but it isn’t regarded as a stain.
leonardturner
PostPosted: Sat Feb 03, 2018 4:18 am    Post subject: Reply with quote
Very interesting comparisons, nicely done and presented. The discussion of KOH is interesting as well. As you may know, the "KOH prep" has often been used diagnostically in medicine to dissolve away flakes of skin gently scraped from a rash, revealing the fungal elements within. I have often done this to good effect.
micro_pix
PostPosted: Sat Feb 03, 2018 7:03 am    Post subject: Reply with quote
Thanks Leonard. I knew KOH was caustic and damaging to skin but I hadn't realised it was used for that purpose.
Here are three photos of hyaline (clear/white) spores. All in water; the first is in brightfield, the second is in darkfield and the third in DIC.
Helvella crispa spores in water.
Entoloma conferendum spores in darkfield.
Laccaria laccata spores in DIC.
Pitufo
PostPosted: Sat Feb 03, 2018 9:39 am    Post subject: Reply with quote
Great images Smile
KMn04 3% can also be used to darken spore colour and allows hyaline spores to be seen more easily https://micro-science.co.uk/product/potassium-permanganate/
Sumguy01
PostPosted: Sat Feb 03, 2018 9:47 am    Post subject: Reply with quote
Very nice.
Interesting and informative.
Thanks for sharing.
PostPosted: Sun Feb 04, 2018 3:29 am    Post subject: Reply with quote
Good job, very nice
vasselle
PostPosted: Sun Feb 04, 2018 2:40 pm    Post subject: Reply with quote
très bon travail et les images sont belles
Microscope Leitz Laborlux K
Boitier EOS 1200d
micro_pix
PostPosted: Sun Feb 04, 2018 2:47 pm    Post subject: Reply with quote
Thanks for the nice comments.
Dave
Walter Piorkowski
PostPosted: Sun Feb 04, 2018 9:53 pm    Post subject: Reply with quote
Very nice project. Enjoying your images. Walt
PostPosted: Mon Feb 05, 2018 5:34 am    Post subject: Reply with quote
+1 enjoying these. What size are the spores, approx?
micro_pix
PostPosted: Mon Feb 05, 2018 10:47 am    Post subject: Reply with quote
Thanks for the comments.
Hi Chris,
The spores are roughly around 8 or 9 microns for the Inocybe spore (they are not all depicted at the same scale) to around 18 microns for the largest of the Panaeolus spores (Panaeolus semiovatus). The Entoloma darkfield was a 40X objective rather than the 100X.
Dave
