www.photomacrography.net :: View topic - Recommendations for bellows lens 00-1x?
JohnyM
PostPosted: Fri Feb 02, 2018 12:42 pm    Post subject: Recommendations for bellows lens 00-1x? Reply with quote
Hello!
As in topic, im looking for recommendadions for bellows lens that covers FF in range of 00-1x. Magnifications im using mostly is 0,1-0,5x. Would like it to be good at F4.
Pentax Auto Bellows. Sony A7RII. Im looking for manual aperture replacement for 100mm Macro for rear bellows stacking.
PostPosted: Fri Feb 02, 2018 2:13 pm    Post subject: Reply with quote
How skinny are your bellows at minimum?
An enlarger lens is an obvious contender, though they need stopping down a bit more than f/4.
I can't think of one which stands out as going to infinity well!
ray_parkhurst
PostPosted: Fri Feb 02, 2018 8:45 pm    Post subject: Reply with quote
The classic lens for this exact purpose is the Nikon 105mm. The older 135mm also works well but does require quite a long bellows extension for 1x.
JohnyM
PostPosted: Sat Feb 03, 2018 8:20 pm    Post subject: Reply with quote
Thanks for input. Technically bellows could be "zero" as i can mount them to mirorless via custom adapter which takes only few milimeters.
Perhaps i should rephraze:
-I dont need real infinity, but i often shoot 10-20 frames at ~0,1x so this is what im aiming for.
-Im using 100mm macro as a workhorse, which works fine for 0,5x-1x but with 0,1x-0,5x im getting an ugly perspective change which forces lots of retouching.
-Due to amount of work, i must have motorized system (manual focusing by ring is out of the question).
-I prefere continous light for modelling and eaze of use which allow for EA8 (which happens to be around diffraction limit).
-I would like to get manual aperture lens, as it seems that stopping down (SAL100mm macro) causes vibrations.
So basically i want to get rid of some retouching and speed up aquisition process.
What i have in mind is:
- Focus by bellows rear
- Using longer lens / teleconverter - im not sure if it will help at all?
- Mounting subject on the rail, instead of the camera.
PostPosted: Sun Feb 04, 2018 4:12 am    Post subject: Reply with quote
Olympus (80mm or)135mm would be easier to find than the Nikon. Aperture smaller than you want, though. Same problem wit hthe Rodagon/Schneider Apo Macro or Enlarging lenses.
Longer lens would help reduce perspective changes, but moving the subject instead of the camera wouldn't. As you say, rear standard focus is the only way to avoid persective change. Unless you cobble together a telecentric arrangement but the glass has to be bigger than the subject for that.
I've wondered about that with the Canon MP-E too! "SAL"?
Hmm
JohnyM
PostPosted: Sun Feb 04, 2018 12:42 pm    Post subject: Reply with quote
Olympus, like macro F4?
I'll try some stacks with 200, 300 and 400 and see if this will be an improvement in my work. Tho not sure how to mount them to rail yet... also gonna need to find where my extension tubes are...
SAL100 stands for sony / minolta 100mm F2.8 macro. I've noticed that i need to increase shutter speed along with stoping down the aperture to get sharp images. So pretty much everytime i stop down by 1 stop, im loosing 2 stops of light.
99% cases im using Mp-e65 wide open, so havent noticed any issues.
