www.photomacrography.net :: View topic - Attach Canon DSLR to Olympus BX51
darwin
PostPosted: Fri Feb 02, 2018 8:28 am    Post subject: Attach Canon DSLR to Olympus BX51 Reply with quote
Hi guys,
I need your expertise again. Do you think this piece is sufficient for attaching a Canon Eos 450D (or newer cameras with similar sensor size) directly on the microscope without having to crop for vignetting?
https://www.benl.ebay.be/itm/Phototube-1X-CCD-C-mount-Camera-adapter-for-Olympus-Microscope-U-TV1X-2-AX-BX41/282459123971?hash=item41c3e03103:g:UXkAAOSwWxNYtbPc
Thanks in advance!
Dieter
Dieter
PostPosted: Fri Feb 02, 2018 12:47 pm    Post subject: Reply with quote
Dieter, this is for C mount cameras that have the sensor much closer to the lens mount (17.526mm if standard) than the Canon EOS (44mm)
The EOS needs to be lower to get parfocality, and likely the C mount could also induce vignette
See the Wiki https://en.wikipedia.org/wiki/C_mount
Some members have done successfully this adaptation, take a look:
http://www.photomacrography.net/forum/viewtopic.php?p=112597#112597
http://www.photomacrography.net/forum/viewtopic.php?p=144389#144389
Likely you will need to figure a custom adapter, if dismountable the adapter you linked lower part could be a good base
Ichthyophthirius
PostPosted: Sat Feb 03, 2018 5:15 pm    Post subject: Reply with quote
Hi Dieter,
Optically, adapting the EOS 450D is very easy. All you need to do is place the camera 60.0 mm above the camera port. http://www.mikroskopie-forum.de/index.php?topic=14927.0 In this position, the intermediate image is projected directly onto the the sensor. No additional optics are needed.
There should be no vignetting if you open the field aperture sufficiently, although the image quality can go down at the edges depending on the objectives you use.
Mechanically, you need an Olympus BX dovetail adapter, a T2 variable length extension and a T2-EOS adapter, together making up 60.0 mm.
I don't know anyone who sells a good BX dovetail adapter but this one could work https://www.ebay.com/itm/112041215905 It's quite expensive and there isn't much information (I haven't tested this one). The alternative would be to have an adapter custom-made.
The adapter you see here http://www.mikroskopie-forum.de/index.php?topic=14927.msg119801#msg119801 was made as Pau suggested: get this adapter https://www.benl.ebay.be/itm/282459123971 , remove the top and use it as the basis for a homemade adapter.
Regards, Ichty
PostPosted: Sat Feb 03, 2018 5:57 pm    Post subject: Reply with quote
I'd be surprised if Rafcamera doesn't have one.
https://www.rafcamera.com/adapters/adapters-for-microscopes/for-microscope-dovetail
And if he doesn't, he'll make you one and add them to his list Smile.
flyer2o12
PostPosted: Mon Feb 05, 2018 7:43 am    Post subject: Reply with quote
Hi Darwin,
This is the adapter I use with my 750D on my BX51 and I do not receive vignetting. It comes with the t-ring.
https://www.ebay.com/itm/For-Olympus-Microscope-with-Nikon-Canon-SLR-DSLR-Camera-adapter-BX41-BX51-MX-CX/112041215905?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
