www.photomacrography.net :: View topic - Regrinding badly scratched front lens of M plan 20x ELWD?
Goto page Previous  1, 2
viktor j nilsson
PostPosted: Mon Feb 05, 2018 6:22 am    Post subject: Reply with quote
Finally had time to do some test stacks.
EDIT: Note that these pictures are taken with three different lenses. First the Nikon E Acrhromat 10x 0.25, then the damaged M Plan 20x ELWD, and finally a fairly nice BD Plan 40x ELWD.
EDIT 2: Note that these are taken with the damaged 20x ELWD shown in my original post. No polishing.
First, I'll just put the pictures here to make sure everything looks as it should. Comments in next post.
First, the full frames, resized in Photoshop:
Nikon E Achromat 10x 0.25
Nikon M Plan 20x ELWD
Nikon BD Plan 40x ELWD
Second, 100% crops (1024 x 1024 px):
E Achromat 10x 100% crop
M Plan 20x ELWD 100% crop
BD Plan 40x ELWD 100% crop
Last edited by viktor j nilsson on Mon Feb 05, 2018 12:27 pm; edited 2 times in total
enricosavazzi
PostPosted: Mon Feb 05, 2018 6:27 am    Post subject: Reply with quote
I was skeptical about the idea, but the proof is in the pudding. Well done!
I guess this particular lens has old-style coatings, which are softer and relatively easy to remove (also accidentally). As a rule, modern multicoatings are much harder than the glass, which makes removing the coating mechanically without damaging the glass problematic.
viktor j nilsson
PostPosted: Mon Feb 05, 2018 6:37 am    Post subject: Reply with quote
The pictures are totally unaltered except for resizing.
Actually, the 20x doesn't look as bad as I had expected.
However, compared to the 40x, its contrast is certainly very low. But the IQ is a quite a bit more uniform over the frame than I had expected.
When I've tried the 20x objective earlier, I had used an adapter (cheap extension tubes + home-made aluminum dovetail adapter) that had no flocking material at all. Before I took these photos, I carefully covered everything with Doodlebug flocking paper. Maybe flocking is especially important when the front lens is damaged?
viktor j nilsson
PostPosted: Mon Feb 05, 2018 6:41 am    Post subject: Reply with quote
I should have been clearer: I still haven't done anything with the lens yet! These are the "before" pictures. So this is the picture produced by the 20x ELWD with a sand blasted front lens. I really thought that it would look much worse than this.
I mainly produced these to have something to compare with IF I went ahead and polished the lens. However, after seeing the picture produced by the 20x, I am starting to hesitate if it is going to be worth it.
viktor j nilsson
PostPosted: Mon Feb 05, 2018 6:46 am    Post subject: Reply with quote
To give you an idea of what I had expected, this is a stack that a friend shot with the 20x ELWD a few weeks ago:
Resized, almost full frame
100% crop
Could cleaning the lens a bit more and adding flocking to the adapter really make such a difference?
viktor j nilsson
PostPosted: Mon Feb 05, 2018 6:58 am    Post subject: Reply with quote
Actually, I realized that I could sort of answer how much an impact the flocking had myself since I also shot a stack of the same subject before I added the flocking material. (I forgot that I did this!).
Full frames without and with flocking:
20x ELWD no flocking
20x ELWD with flocking
And 100% crops without and with flocking:
100% without flocking
100% with flocking
neurodoc
PostPosted: Mon Feb 05, 2018 1:34 pm    Post subject: Reply with quote
You could try making a lap by mixing up some Jett Ballistic Fixturing Material(this is a plastic that is softened in hot water, molded into shape while soft, and allowed to set up hard). You can get it in jeweler supply houses, like Otto Frei). This sets up much harder than waxand would give you a fairly accurate negative surface to use as a formed lap while you polish the lens. It just might do the trick.
Man sieht nur, was man weiss--Goethe
Page 2 of 2
