www.photomacrography.net :: View topic - Nikon CFW 10x eyepiece
dragonblade
PostPosted: Fri Jan 26, 2018 11:01 pm    Post subject: Nikon CFW 10x eyepiece Reply with quote
Ive just received a Nikon CFW 10x eyepiece which is supposedly high eyepoint. It is also a focusing eyepiece. It was suggested that you can get away with not focusing it by setting the diopter to 0. However, I'm not sure which ring is for diopter adjustment (there are two manual rotating rings.) The ring that is closest to the eye is considerably thicker. Also, I don't see any numbers on either of the rings so not sure how I could set the diopter to 0.
Ichthyophthirius
PostPosted: Sat Jan 27, 2018 5:14 am    Post subject: Reply with quote
You can find the "0" in several ways.
- Use a non-focussing DIN eyepiece as a reference or:
- On a properly set-up microscope, find the eyepiece position in which all objectives are parfocal (from low to high magnification, e.g. 4-40).
To do this, use the objective 40 to focus (stage) on an object, then go back to the 4 and focus the eyepiece until the object is in focus again. Go back to the 40, focus using the stage again, go back to 4 and focus with eyepiece again. All objectives should now be parfocal and the eyepiece should be in 0 position.
dragonblade
PostPosted: Sat Jan 27, 2018 5:39 am    Post subject: Reply with quote
Thankyou for those instructions. As previously mentioned, there are two rings on the eyepiece. Which would be the focusing ring - the one closest to the eye or the one further away?
Ichthyophthirius
PostPosted: Sat Jan 27, 2018 6:14 am    Post subject: Reply with quote
Not sure what you mean. The lower ring might possibly be part of the lower eyepiece tube. It might come off eventually.
The correct ring moves the top of the eyepiece containing the optics. It opens a gap below the "CFW 10x" lettering, as seen here:
http://www.prc68.com/I/Images/NikonCFW10xs.jpg
There is also a white line being exposed when you turn it. This could possibly mark the "0" position:
https://ssli.ebayimg.com/images/g/M7cAAOSwEzxYZbtg/s-l1600.jpg
dragonblade
PostPosted: Sat Jan 27, 2018 2:32 pm    Post subject: Reply with quote
Well since it's a focusing eyepiece, I assume it would have a focus ring, just like a photographic / camera lens. I can't visualise any other way to focus the eyepiece other than rotating a ring.
Ichthyophthirius
PostPosted: Sat Jan 27, 2018 2:40 pm    Post subject: Reply with quote
Ah, I see. I was wondering why you had two focussing rings. I assume what you mean is: which of the two curdled rings is the focussing ring?
The one on top. It moves the entire upper part of the eyepiece as you can see in my first link.
dragonblade
PostPosted: Sat Jan 27, 2018 2:51 pm    Post subject: Reply with quote
Thanks again for clarifying. When I find the "0" position, I'll duct tape it in place.
