www.photomacrography.net :: View topic - How To Use Diaphragm With Mitty Lenses
lonepal
PostPosted: Mon Jan 22, 2018 12:43 pm    Post subject: How To Use Diaphragm With Mitty Lenses Reply with quote
Hi;
I am currently using a Mitutoyo 5X with a Sigma LSA and also a diaphragm between them.
All of them mounted in front of a Pentax bellows.
Sensor-Sigma LSA=200mm
Mitty-Sigma LSA=76-77mm
Source for Mitty-Sigma distance;
http://www.photomacrography.net/forum/viewtopic.php?t=25321&postdays=0&postorder=asc&start=22
I made some trials but I think I lost details when I close the aperture a bit.
I think this is because I am so close to the diffraction limit.
Is it useful to use a diaphragm with Mitty lenses?
If so, how do you use it?
Please advice me about using it.
Thanks.
Regards.
Omer
PostPosted: Mon Jan 22, 2018 5:25 pm    Post subject: Reply with quote
You will lose resolution when you close the aperture.
Two uses -
#1) when you only need a small picture, perhaps 1000 pixels wide, so you can use a smaller aperture for more DOF. You wouldn't see the finest detail anyway.
#2) more usefully, to add frame(s) at the end of the stack. This makes the transition from sharp to blurred much more gradual, and out of focus background features become recognizable. If you mark your aperture ring so you can reliably set, say, 4 stops smaller, then you can increase the exposure by that amount.
Align the extra frame but don't include it in the stack. Re-stack it with the output image, afterwards. The reason is that in-focus details will appear in strange places, which you don't want.
lonepal
PostPosted: Mon Jan 22, 2018 10:46 pm    Post subject: Reply with quote
Thanks Chris.
This is very useful information for me.
I will use the diaphragm as you told.
Regards.
Omer
dolmadis
PostPosted: Tue Jan 23, 2018 1:17 am    Post subject: Reply with quote
I am sorry but I am struggling to understand the procedure.
HELP !!
BR
John
Adalbert
PostPosted: Tue Jan 23, 2018 10:06 am    Post subject: Reply with quote
Hi Chris,
What do you think about that:
#3: to look for the interesting object/detail with the closed iris and to take the photographs with the open one
BR, ADi
PostPosted: Tue Jan 23, 2018 10:33 am    Post subject: Reply with quote
Adalbert, if I may chime in, that is a very good use for an iris. There are often surprises in the construction of a stack, since not all elements of the subject are visible at the same time. An iris increases the odds that you'll see the whole composition correctly.
www.loujost.com
