www.photomacrography.net :: View topic - Dimensions for Zeiss Standard RA
engelmanna
PostPosted: Thu Jan 18, 2018 9:04 pm    Post subject: Dimensions for Zeiss Standard RA Reply with quote
I’m a 3D artist looking to model a Zeiss Standard RA microscope. I’ve found plenty of imagery online for reference, however after a day of scouring the internet, I can’t seem to find any reliable dimensions online. I was hoping someone here on the forums with access to a Zeiss Standard RA could help me get the following dimensions:
(image below illustrating listed dimensions)
H1 - Height from bottom of base to top of stand
H2 - Height from top of base to top of block
H3 - Height from bottom of base to top of base
D1 - outer diameter of top of stand
D2 - outer diameter of nosepiece
D3 - diameter of dial
D4 - diameter of illuminator?
W1 - width of base
Any other dimensions you think would help would be greatly appreciated as well, however I think i can extrapolate everything I need from this set of dimensions.
Thanks!
PostPosted: Fri Jan 19, 2018 1:27 am    Post subject: Reply with quote
Nice project!
If you don't need top precision measurements I'll do in few days. Mines are not exactly the RA, but I have Standard 16 and 18 and dimensions are really the same.
There are some other important dimensions I'd also could measure
Eddie
PostPosted: Fri Jan 19, 2018 5:11 am    Post subject: Reply with quote
The dimensions of H2 is variable as it is the focus height of the stage. Currently it shows it in the upper most position.
I have an RA and can get you some measurements this weekend.
engelmanna
PostPosted: Fri Jan 19, 2018 5:26 am    Post subject: Reply with quote
Thanks for the responses!
@Pau - The 3d model is just for visual sake. The measurements do not have to be supper accurate.
@Eddie - Thanks for catching the variable H2 issue. If you do get measurements, could you measure it at both it's highest and lowest point?
Eddie
PostPosted: Sat Jan 20, 2018 9:44 am    Post subject: Reply with quote
The dimensions of the Zeiss RA body:
H1 - 270mm
H2 - 98 - 123mm
H3 - 40mm
D1 - 62mm
D2 - 68mm
D3 - 55mm
D4 - 55mm
W1 - 168mm at the bottom of the base but is 140mm at the top of the base
These are some measurements which you didn't ask for but may want:
L1 - 225mm This is the total length of the base, front to back, measured from the bottom but only 210mm on the top of the base.
L2 - 82mm Length of the arm on top of the base without the condenser/stage carrier.
W2 - 46mm Width of the arm at the front sitting on top of the base
engelmanna
PostPosted: Sat Jan 20, 2018 2:29 pm    Post subject: Reply with quote
Thank you Eddie for the measurements! These should give me enough to work from to get an accurate 3d model.
