www.photomacrography.net :: View topic - Diffusion Solved?
Diffusion Solved?
Goto page 1, 2, 3  Next
Deanimator
PostPosted: Wed Jan 17, 2018 7:31 pm    Post subject: Diffusion Solved? Reply with quote
I think I've finally gotten my diffusion issues under control.
I went back to my PVC and packing sheet diffuser that I use for guns and other still life's. I made it narrower and used four layers of Office Max foam packing sheets for diffusion.
MarkSturtevant
PostPosted: Thu Jan 18, 2018 6:42 am    Post subject: Reply with quote
Looks good!
Mark Sturtevant
Dept. of Still Waters
PostPosted: Thu Jan 18, 2018 9:04 am    Post subject: Reply with quote
Good, but there are still residual sparkles on narrow ridges....
www.loujost.com
MarkSturtevant
PostPosted: Thu Jan 18, 2018 11:41 am    Post subject: Reply with quote
I am curious to see what this diffuser looks like. I have similar materials laying around and I am always trying to develop a 'new and improved diffuser'.
Mark Sturtevant
Deanimator
PostPosted: Thu Jan 18, 2018 1:32 pm    Post subject: Reply with quote
True, but it's still a VAST improvement.
That was actually the product of VERY brief work between getting up and having to go to work.
Now that the basic concept has been validated, I can fine tune it by adding additional diffusion material and or repositioning the Jansjos. I haven't even tried with the flashes yet.
I need to make it a little narrower still in order to comfortably fit between the t-channels in which my magic arms are mounted. It could probably stand to be slightly shorter lengthwise in order to fit better on the cutting board mount, especially at lower magnifications and longer camera to subject distances.
Deanimator
PostPosted: Thu Jan 18, 2018 1:41 pm    Post subject: Reply with quote
I'll try to post a picture by Sunday.
It's based on a design I got from a gun collector's forum I'm on. Gun forums always have lots of gun pictures, and guns are almost invariably shiny and require diffusion, at least when shot in the studio.
It's similar to the portable fabric hangars they used during WWI to work on aircraft where there were no permanent facilities, like Russia. The diffuser is the "hanger", and the camera and subject stage are the "airplane", only I move the hangar over the plane, not the plane into the hanger.
Since it's unglued PVC, it's endlessly reconfigurable merely by changing the lengths of the 1/2" tubes or the angles of the legs (if you use street elbows and not fixed ones).
johan
PostPosted: Thu Jan 18, 2018 2:04 pm    Post subject: Reply with quote
Great stuff!
Deanimator
PostPosted: Thu Jan 18, 2018 6:21 pm    Post subject: Reply with quote
Here's a crop of a cuff link, one of my harder subjects.
It's cropped only because I messed up the focus on the right side.
It could probably use a bit more diffusion or moving the lamps away a little more.
PostPosted: Fri Jan 19, 2018 3:23 am    Post subject: Reply with quote
All the packing materials I've considered as diffusers, haven't been very good.
Looking through them at a bright light, there's always been a hot spot in line with the light.
Paper, either normal office, or tissue, is good.
Cooking/drawing translucent papers are stiffer.
The stationery shop man is now used to me rifling through his stock and holding file covers and folders up to stare through them at a bright light
Some are good enough to stand over the subject as a tent.
Having a gap between the layers helps a lot, too.
Deanimator
PostPosted: Fri Jan 19, 2018 9:33 am    Post subject: Reply with quote
A while back, I bought a bunch of stuff as potential diffusion media.
I've also got some tracing paper I can try.
PostPosted: Fri Jan 19, 2018 9:46 am    Post subject: Reply with quote
The translucent stuff that's on the cheap eBay light tents works well. These small tents are just $10~15 and work well. I just remove the velcro side and set the tents over the entire subject and mounting fixture, then a slit that I cut on one side allows the camera lens to poke thru inside the tent.
~Mike
MarkSturtevant
PostPosted: Fri Jan 19, 2018 1:55 pm    Post subject: Reply with quote
I too am always riffling through the recycling bin at work, and skulking in stores for diffuser materials. I am sure I have gotten strange looks by holding up translucent notebooks to the light, and taking pictures of cheap plastic light globes (some of those are potentially good diffusers) Smile
As for a hot spot, it seems to me that as was said you can directly block or attenuate light that would make a hot spot. I have blocked it by using my left hand over that area. I also sometimes tape on something that is handy like a leaf over the spot. This has helped but not always. Attenuating the hot spot is by adding additional layers of material over it. Right now my current favored diffuser (a big piece of transluscent plastic milk jug) has a few layers of white tracing paper over the hot spot area. It definitely helps. And I can then add more by blocking as described above.
Mark Sturtevant
PostPosted: Fri Jan 19, 2018 2:39 pm    Post subject: Reply with quote
One of the advantages of using multiple light sources is you can blend the sources with diffusion and help reduce bright spots. Also, you can control the output of the various sources and create intensity gradients for specific effects.
~Mike
Deanimator
PostPosted: Fri Jan 19, 2018 2:51 pm    Post subject: Reply with quote
Right now, I'm doing a 205(?) image stack of the same cuff link.
I added another double thickness of packing sheet, for a total of eight layers.
I won't be able to try any other modifications until I'm off on Sunday, and then probably not until late in the day.
Deanimator
PostPosted: Fri Jan 19, 2018 5:24 pm    Post subject: Reply with quote
With eight layers of diffusion and better focus. The framing could be a bit better:
Page 1 of 3
