View previous topic :: View next topic |
Author |
Message |
pentax360
Posted: Fri Jan 12, 2018 4:10 pm Post subject: Stacking not working, what am I doing wrong? |
This is my first foray into macro stacking and I’m having some trouble.
I've done some non macro stacking and it’s worked fine.
I’m using an APSC sensor camera with a full frame macro lens, so I don’t know if when using the 1:1 marking on the lens if it’s correct when using the calculator.
I’m taking a photo of a 1 1/4 inch long toy.
The magnification/focus was left unchanged between shots and the camera was moved on a milling machine table.
I used this calculator:
http://extreme-macro.co.uk/focus-stacking/#calculator
I put in APSC, f11, 1:2 (in the calculator I put .5:1), it told me to do steps of 1.881 mm.
I ended up with 25 photos I ran them through zerene, (and also a couple of other stackers) and this is what I end up with.
I’ve tried this a few times with similar results.
What am I doing wrong?
Am I trying to get too much in focus, are my stacks not the right distance?
Any help would be greatly appreciated.  |
Back to top |
rjlittlefield Site Admin
Joined: 01 Aug 2006 Posts: 19546 Location: Richland, Washington State, USA
Posted: Fri Jan 12, 2018 4:21 pm Post subject: |
I can see from the dust trails that you have alignment turned on, but it's clear that you have an alignment problem. So then my best guess is that the fuzzy bright bar running vertically across the whole frame is in far background, so it shifts across the subject as you step focus. In that case it's not possible for the software to keep everything aligned at once, and because the bar is big, the software is likely to lock onto the bar at the expense of your subject.
I suggest for starters to place your subject in front of a uniform featureless background. Shoot another stack and see if that works out better for you.
By the way, is this scene supposed to be relentlessly blue, or is there some issue with color balance?
--Rik |
Back to top |
pentax360
Posted: Fri Jan 12, 2018 6:12 pm Post subject: |
Thanks that makes sense but I hadn't thought of it.
I'll try another one with a background.
The white balance is fine, it's just in my garage with some off color florescent lights and I didn't bother to correct it. |
Back to top |
pentax360
Posted: Sun Jan 14, 2018 12:27 am Post subject: |
That worked!
thanks a lot.
Also I need to clean my sensor  |
Back to top |
Posted: Sun Jan 14, 2018 12:30 am Post subject: |
Looks much better. Yep, there's nothing like focus stacking to make sensor spots visible.
--Rik |
Back to top |
Deanimator
Joined: 23 Oct 2012 Posts: 626 Location: Rocky River, Ohio, U.S.A.
Posted: Sun Jan 14, 2018 8:54 pm Post subject: |
rjlittlefield wrote: | Looks much better. Yep, there's nothing like focus stacking to make sensor spots visible.
--Rik |
Don't I know it! |
Back to top |
