www.photomacrography.net :: View topic - Olympus BH2-BHTU Stand
dolmadis
PostPosted: Tue Jan 02, 2018 10:47 am    Post subject: Olympus BH2-BHTU Stand Reply with quote
As some readers might have noticed in the Equipment Exchange Forum I am looking for a BH2 series stand; BHS or BHT.
But I am wondering if the BHTU Stand is also in scope for what I want to do?
I have read the documents on Alan Wood's Olympus Web Site but I am still a little uncertain about how far the modular approach extends in the BHTU.
I cannot find confirmation of the following so I am asking here to tap the experience and knowledge of the forum.
I think that the BHTU turret, which is described as reversed and fixed, is RMS.
So the first assumption I have is that subject to the objective to objective seperation I could mount an M25 NEO SPLAN (BF/DF EPI) to RMS using an M25 to RMS adapter.
The second assumption is that because the BHTU brochure (http://www.alanwood.net/downloads/olympus-bh-2-bhtu-brochure.pdf) shows that the reflected light fluorescence attachment BH-RFL-W can be mounted above the turret and this can take a BH2-TR30 then I could singly also mount a BH2-RLA or a BH2-MA and have EPI imaging.
This makes sense to me but can anyone confirm before I also look for a BHTU stand.
BR and Thanks
John
Alan Wood
PostPosted: Tue Jan 02, 2018 11:21 am    Post subject: Reply with quote
John
The BH2-MA does fit on a BHTU. According to the BHM brochure, the BH2-RLA fits too.
The BHTU nosepiece is RMS.
The Neo S Plan objectives are 26mm thread, not 25mm.
You might be able to mount a Neo S Plan with an adapter to RMS. However, I suspect that this would block the light path for DF illumination.
Alan Wood
CORRECTION
The BHM brochure does not include the BHTU stand, I got confused.
My BH-RLA has a protrusion underneath that prevents it being attached to a BHTU. It is possible that the BH2-RLA has the same problem, but I do not have one to check.
Alan Wood
dolmadis
PostPosted: Tue Jan 02, 2018 11:27 am    Post subject: Reply with quote
Thank you Alan that is very helpful.
BR
John
