www.photomacrography.net :: View topic - Flare in images
Flare in images
soldevilla
PostPosted: Sat Dec 30, 2017 5:00 am    Post subject: Flare in images Reply with quote
Maybe it's my perception, but retouching with Zerene the areas in which the flare has occupied the areas around the highlights, even though the individual images evidently do not show flare, there is always a loss of contrast in that area that is very difficult to recover, trying to "cheat" by saving stacked images of 2 individual images and using Photoshop. There is no way to adjust the hardness of the touch-up application?
PostPosted: Sat Dec 30, 2017 9:03 am    Post subject: Reply with quote
It would help to see an example of what you're talking about, both the stacked output that you're trying to retouch, and the individual images.
Hardness of the brushes depends on which brush you're using. The default "Details" brush does not have a hardness adjustment that you can control. It is automatically hard for fine detail, less hard for larger detail, as discussed at http://www.photomacrography.net/forum/viewtopic.php?p=85715#85715. The 'Pixels" brush does have adjustable hardness, with a slider control very much like Photoshop's clone brush.
soldevilla
PostPosted: Mon Jan 08, 2018 5:56 am    Post subject: Reply with quote
Hi. Because I no save the work steps I not have now an example. I will save next time I find this effect. But in your link there is a perfect example
http://www.photomacrography.net/forum/userpix/6_ZS_brush_hardness_50pct_1.jpg
After read your link, I have a better idea that how Zerene work. The final picture need some post work in Photoshop... It will be fine if Zerene Allow me to save individual, aligned images. But I can stack two adjacent images and save, and use this image in PS
About brushes, I not have the Pro version...I have only the default brushes.
Thanks!
PostPosted: Mon Jan 08, 2018 9:26 am    Post subject: Reply with quote
This is provided at File > Save Other > Save Adjusted Input Images.
But it is another Pro-only feature.
