Hi Gang
I have had a moth specimen for a while and I found the antenna interesting
due to the curve at the end. I also find it interesting that the antenna
also contains scales.
I wonder that, when alive, the scales get removed by the normal aspect
of living and avoiding any predators, or is the antenna only partially
covered.
The antenna measures about .75 of an inch.
Moth antenna 10x
Moth antenna 10x
The scale pattern shown here looks fresh to me, not worn. You can see how nicely the pattern of scales repeats from one segment to another.
It is not unusual for some antennae to be scaled.
But I do not recognize the form of this particular antenna. It is oddly thick and smooth. What sort of moth is it from?
Moths are often nocturnal. This article (link below) suggests the scales on some moths reduce the echo return that would help a bat detect them.
http://journals.plos.org/plosone/articl ... ne.0027190
I think the lay of the scales may also reflect the echo away from the bat further disguising the moth. A bit like some stealthy aircraft. Some moths also fold their wings together allowing themselves to flutter down to the ground like a dead leaf when they are detected. Another survival strategy.
The coloration may also help it avoid capture during the day.
So I suspect the scales are part of the stealth package.
Keith
Keith
