www.photomacrography.net :: View topic - Inexpensive dark field adapter
dmillard
PostPosted: Thu Dec 28, 2017 12:48 pm    Post subject: Inexpensive dark field adapter Reply with quote
A quick and easy “dark field” adapter made from a solar cigarette lighter, readily available on eBay for just a few dollars (see for example here).
I removed the metal coil, and cut a plastic vial to reach the position at which the end of the cigarette would rest in the coil (the focus of the parabola). I stuck a small piece of black flocking material on the inside of the lighter, and glued a disc magnet on the convex base to provide a level support (a washer would work as well).
The image of the seed was taken with this setup using a combination of incident and dark field illumination.
Castilleja sp., Mitutoyo 7.5X M Plan Apo, NEX 7
PostPosted: Thu Dec 28, 2017 3:56 pm    Post subject: Reply with quote
Well how do you like that! Reminds me of an ascomycete, a morel.
PostPosted: Thu Dec 28, 2017 3:58 pm    Post subject: Reply with quote
Ingenious Smile. Now with a ring flash...
PostPosted: Thu Dec 28, 2017 4:47 pm    Post subject: Reply with quote
Nice and effective!
How do you illuminate the mirror?, maybe with a ring of light from the rear of the subject (what's called a Lieberkühn reflector)?
http://www.alanwood.net/photography/olympus/lieberkuhn-reflectors.html
JH
PostPosted: Thu Dec 28, 2017 5:03 pm    Post subject: Reply with quote
Hi
Nice picture and thanks for the idea!
I like the black background. Did you get it this black when photographing, or was it necessary to darken it in post processing?
Best regards
Jörgen Hellberg
Jörgen Hellberg, my webbsite www.hphoto.se
dmillard
PostPosted: Fri Dec 29, 2017 8:26 am    Post subject: Reply with quote
Pau wrote:
Nice and effective!
Thanks Pau. I used a pair of Novoflex Macrolight Plus lights, with Vivitar 183 flashes. See here
Thanks Jörgen. The black disc resting in the concavity is cut from an extremely light-absorbent material, Doodlebug Design Beetle Black Crushed Velvet Cardstock, see here and here , so apart from retouching around the immediate edge of the seed, there was no need to darken the background.
PostPosted: Sat Dec 30, 2017 12:40 am    Post subject: Reply with quote
Very good and useful post, David! Very Happy
This is precisely what I thought. Do we both have morchellaceae on the brain?
JH
PostPosted: Sun Dec 31, 2017 10:08 am    Post subject: Reply with quote
Thank you very much for that information.
Best regards
Jörgen Hellberg
cube-tube
PostPosted: Fri Jan 05, 2018 7:47 pm    Post subject: Reply with quote
Bought!
