www.photomacrography.net :: View topic - Hippeastrum flower pollen
Goto page 1, 2  Next
JH
PostPosted: Tue Dec 26, 2017 12:47 pm    Post subject: Hippeastrum flower pollen Reply with quote
Nikon ELWD 100x, Canon 6D, EPI-light, Zerene Stacker Adobe PS and LR, Topaz ReMask 5. I used quite a lot of sharpening, and blurred out the background.
Best regards
Jörgen Hellberg
Jörgen Hellberg, my webbsite www.hphoto.se
PostPosted: Tue Dec 26, 2017 2:06 pm    Post subject: Reply with quote
Impressive! How deep is the stack (frames & microns) ?
PostPosted: Tue Dec 26, 2017 3:08 pm    Post subject: Reply with quote
Excellent, the stereo helps a lot to see the actual shape of the pollen texture
JH
PostPosted: Tue Dec 26, 2017 3:34 pm    Post subject: Reply with quote
Thanks Rik and Pau!
The lens is NA 0.8 so usually a step size close to 0.0005 mm (0.5 microns) will be OK with a little marginal.
I was trying to do a depth map where the dents could be seen. To do this I had to have smaller than normal steps. In this case I used 0.0001 mm (0.1 micron), so 319 pictures covered the distance of approx. 0.032 mm (32 microns).
Best regards
Jörgen Hellberg
PostPosted: Wed Dec 27, 2017 2:02 am    Post subject: Reply with quote
Good job, Very nice
PostPosted: Thu Dec 28, 2017 2:29 am    Post subject: Reply with quote
So alien, so unearthly in appearance. Wonderful photograph!
JH
PostPosted: Thu Dec 28, 2017 4:55 am    Post subject: Reply with quote
Thanks Ken Ramos and Jacek!
Best regards
Jörgen Hellberg
PostPosted: Thu Dec 28, 2017 5:10 am    Post subject: Reply with quote
Nice!
Olympusman
PostPosted: Thu Dec 28, 2017 9:10 am    Post subject: Pollen Reply with quote
Lovely.
JH
PostPosted: Sun Dec 31, 2017 10:12 am    Post subject: Reply with quote
Thanks Carlos and Mike.
Best regards
Jörgen Hellberg
JH
PostPosted: Thu Jan 18, 2018 2:21 pm    Post subject: Reply with quote
I was interested in trying to have a clean black background. Tried some different options. For this BW-picture I used a Nikon plan apo 40x BD 210 mm lens, dark field, and green light (GIF-filter). The green light helped even though this was an APO-lens.
And a 2D stereo made with Zerene.
Best regards
Jörgen Hellberg
Saul
PostPosted: Thu Jan 18, 2018 2:57 pm    Post subject: Reply with quote
Jörgen , result is really beautiful !
Saul
JH
PostPosted: Sun Jan 21, 2018 12:22 pm    Post subject: Reply with quote
Thanks Saul Very Happy
Best regards
Jörgen Hellberg
WalterD
PostPosted: Fri Feb 02, 2018 11:53 am    Post subject: Reply with quote
Congratulations, the green light filter turns out to be a very good choice.
Smile
Best regards,
Walter
www.waltermachielsen.com
PostPosted: Fri Feb 02, 2018 12:37 pm    Post subject: Reply with quote
Beautiful monochrome shot. If you want to push this farther, you might want to use violet lasers and a cooled monochrome camera.....you'd achieve 20% more resolution and get smooth backgrounds with no thermal noise.
www.loujost.com
Goto page 1, 2  Next
Page 1 of 2
