www.photomacrography.net :: View topic - Amscope 4x IQ?
Amscope 4x IQ?
Goto page Previous  1, 2
zzffnn
PostPosted: Mon Dec 25, 2017 6:44 pm    Post subject: Reply with quote
tevans9129,
Sorry to be so blunt. I also think you need more even diffusion. With that perfected, most of your concerns may be solved.
If you look into the spider's eye ball, you can see that there was strong light from 3 o'clock position, some weaker light from about 9 o'clock position and not much light from anywhere else.
Maybe try a DIY diffusion tent/cone, say made with layers of Vellum paper, that VERY CLOSELY matches the size of your subject. And provide more fill light. This let's light source appear very close to your subject.
If you diffusion tent is much bigger, then your light source will appear much smaller and further away, from the subject's point of view. That means harder light and more reflection.
I remember seeing your macro rig and its diffusion tent appears slightly too big for small insects.
tevans9129
PostPosted: Mon Dec 25, 2017 7:56 pm    Post subject: Reply with quote
rjlittlefield wrote:
Here is my version of the rework.
Yep, the fly looks good.
Thanks for all the help Rik, subject condition plus the lighting on the spider rather than the Amscope. That makes me feel better.
Yawns
PostPosted: Mon Dec 25, 2017 8:11 pm    Post subject: Reply with quote
I know nothing of theory, but I experiemnt a lot and take conclusions for observation
It helped me a lot to understand what's going on with light when I read these 2 articles:
- Apparent size of light
http://strobist.blogspot.pt/2007/07/lighting-102-unit-21-apparent-light.html
and
- Specular highlight control
http://strobist.blogspot.pt/2007/07/lighting-102-unit-22-specular-highlight.html
It works for me (maybe for you don't) .. it's just my experience.
1. Put the light source as close as possible to the subject .
2. Make the last piece of the diffusion system as small as possible and very close to the insect.
the more the light is away .. the more hotspots you get
the more the difuser surface is away from the insect .. the worse is the distribution
the bigger is the diffuser (more away from the subject) the more edgy are the transitions from light to shade
everything well packed and tight works fine for me ...
tevans9129
PostPosted: Tue Dec 26, 2017 7:28 am    Post subject: Reply with quote
Yawns, thanks much for the images, links and information, very informative.
Page 2 of 2
