www.photomacrography.net :: View topic - My current setup for image stacking
tevans9129
PostPosted: Tue Dec 19, 2017 4:51 pm    Post subject: My current setup for image stacking Reply with quote
This is a work in progress and thanks to others for posting images of their setups as they have given me great ideas as to where to start. This is where I am now but things are still evolving, lighting is one of the major subjects.
Base is two layers of 3/4" MDF for weight and stability with 7/8" hickory that the 1.5x1.5 aluminum rail is set into.
Close-up of the subject area.
My rendition of the laser sighter as taken from the images provided by Chris S., thanks millions Chris. I use two AAA batteries but thinking about adding a third one. The unit locks into the hot shoe.
I want to do some more experimenting with the idea. It may work with some improvements in lighting. I will probably add a couple of speedlights next.
A couple of adapters have been ordered from China but being ignorant of this equipment, I am not for certain that I even ordered the correct adapters. I made this tempory adapter by having a snug fit over the reversing ring and boring the hole for the Amscope 4x approximately .001 undersize. It seems to screw in fairly snuggly and indexed on the shoulder.
Would love to hear ideas and suggestions of others for improvements. Feel free to post images in this thread if that will help.
NikonUser
PostPosted: Wed Dec 20, 2017 1:57 pm    Post subject: Reply with quote
very nice setup.
Images would be improved if you replaced the Amscope 4x with a
4x Nikon CF Plan Apochromat NA 0.2.
Your current 4x seems the weakest link in the system
NU.
student of entomology
Oliver Wendell Holmes, Sr
tevans9129
PostPosted: Wed Dec 20, 2017 5:30 pm    Post subject: Reply with quote
NikonUser wrote:
very nice setup.
Thank you for the suggestion. Using objective lens is a totally new experience for me and to which I know nothing about. My idea of the Amscope lens was to get my feet wet without spending much on something I know nothing about. At the moment, my interest seems to be in the 1 to 10x range and I do plan on acquiring some better optics in the future. Of course, cost is an unfortunate issue.
PostPosted: Wed Dec 20, 2017 8:05 pm    Post subject: Reply with quote
That particular 4X objective appears to be the one that tested very well in Robert OToole's tests, especially with respect to corner performance on full-frame sensors like the D800E. In comparison the plan apochromats fell off pretty badly in the corners.
See Robert's threads at http://www.photomacrography.net/forum/viewtopic.php?t=34277 and at http://www.photomacrography.net/forum/viewtopic.php?t=36028 and http://www.photomacrography.net/forum/viewtopic.php?t=36071 , and the corresponding more detailed reports on his web site at https://www.closeuphotography.com/4x-lens-test/part-one-4x-for-less-than-100-dollars and https://www.closeuphotography.com/4x-test-part-two-high-end-objectives .
NikonUser
PostPosted: Thu Dec 21, 2017 4:18 am    Post subject: Reply with quote
Not being in the market for any more lenses I did not read Robert's report on 4x's.
I did recall seeing a spider face with the Amscope 4x:
http://www.photomacrography.net/forum/viewtopic.php?t=36082
It does not seem to be a high image quality. I know I could get a better image quality with my Nikon 4x Apo; I use it with a 1.4x teleconverter (primarily to keep dust off the camera's sensor) which helps in reducing corner vignetting on a full frame.
NU.
PostPosted: Thu Dec 21, 2017 5:15 am    Post subject: Reply with quote
Even on Expanded Live View, the planapos definitely look sharper in the middle.
One has to ask how important the corners are, how much the CA corrects, etc. For many subjects they wouldn't actually be a problem, so I expect the planapos would make a better picture.
For a specimen, whole animal shot with a plain background, no contest.
The cheap Amscope is remarkable for the price though, and "good" at any price.
PostPosted: Thu Dec 21, 2017 5:55 am    Post subject: Reply with quote
Here's an image of the AmScope 4X in action on another site. Maybe not in the Mitty realm, but for $18 as someone mentioned, "a Jewel in the Rough". I use it often if not looking for the absolute best image, and certainly easier to get setup and going without having to deal with a tube lens with the Mitty's.
https://4.img-dpreview.com/files/p/E~forums/60536032/e0b7b3d1d4bd49918c271b1d9001be14
Best & Happy Holidays,
PostPosted: Thu Dec 21, 2017 6:06 am    Post subject: Reply with quote
tevans,
Your laser pointer is very interesting, really like the use of the Hot Shoe on the D800E. Could you provide a separate thread and give us some details?
I suspect this requires a custom machined fixture to mount on the Hot Shoe and hold the laser at the right position and angle.
tevans9129
PostPosted: Thu Dec 21, 2017 10:31 am    Post subject: Reply with quote
mawyatt wrote:
tevans,
Thanks for the comments Mike, I posted here.
http://www.photomacrography.net/forum/viewtopic.php?p=224136#224136
Yawns
PostPosted: Thu Dec 21, 2017 11:19 am    Post subject: Reply with quote
I only did one stack with the AmScope so far .. did not have time for more as I got it very recently ..
the picture is here and in Flickr it can be expandd to full size..
I believe I will use it a lot more in th future...
I'm very pleased how well it captured the tinny hairs in between the eye clusters... specially on the left side where the light is better ...
https://flic.kr/p/217zZZW
2017-12-05 #Testing AmScpe 4X 0,1 Plan 160/0,17 by Antonio Caseiro, on Flickr
tevans9129
PostPosted: Thu Dec 21, 2017 11:23 am    Post subject: Reply with quote
Nice shot, any details?
Yawns
PostPosted: Thu Dec 21, 2017 2:22 pm    Post subject: Reply with quote
as it was a try I did not take notes of the details but have to be shot very much like this one ...
https://www.photomacrography.net/forum/viewtopic.php?t=35990&highlight=
it's the same animal .. I used continuos light for 3" seconds exposures.. and only the 2 top side lights of the hexagon... camera setting have to be the same.
