www.photomacrography.net :: View topic - Full frame 6x-10x recomendations?
JohnyM
PostPosted: Mon Dec 11, 2017 3:39 pm    Post subject: Full frame 6x-10x recomendations? Reply with quote
Any recomendations for lens between 6x and 10x that covers full frame? Due to subject nature i need good corners. I need a bridge between Mp-E65 and episcope.
A7RII no AA; 4,5um pixel pitch; bellows or tube mounted. I've got good 100mm/135mm/200mm tube lenses.
At the moment im using Nikon BE Plan10x that gives me good 135-200mm and acceptable 100mm corners on Aps-C. Looking for something similar for full frame as i would like to ditch aps-c for microscopy only.
PostPosted: Mon Dec 11, 2017 4:24 pm    Post subject: Reply with quote
Look at Mitutoyo 7.5x?
JohnyM
PostPosted: Mon Dec 11, 2017 5:13 pm    Post subject: Reply with quote
Any reason to pick it over 10x which have higher Na, almost same WD and is much cheaper?
PostPosted: Mon Dec 11, 2017 5:27 pm    Post subject: Reply with quote
Yes. The 7.5X has a much larger image circle, so it provides a lot more freedom for adjusting magnification up or down with different tube lenses.
See http://www.photomacrography.net/forum/viewtopic.php?p=208243#208243 and the surrounding thread.
