www.photomacrography.net :: View topic - Newbie second attempt
stephenlewis
PostPosted: Wed Dec 06, 2017 3:09 pm    Post subject: Newbie second attempt Reply with quote
Hello everyone.
Second attempt at this macro thingy!
The photograph was taken using a Nikon D800, a Nikkor 50mm enlarging lens reverse mounted on a set of bellows, all mounted on a Wemacro rail. The subject was a Green and black horned beetle (Mystroceros rouyeri). The lighting was two flash units, which are new to me and took a while to fathom.
I finished up with 90 photographs, which were divided into three stacks each with 30 photographs. Each individual stack was processed using Zerene Stacker to produce a Dmap image, and the three resulting images were then stacked into a final image using Dmap. The final image was processed using a combination of Photoshop and Topaz.
Stephen.
www.stevelewis.photography
BugEZ
PostPosted: Wed Dec 06, 2017 3:38 pm    Post subject: Reply with quote
Wow! Excellent work! Shiny beetles can be quite tricky.
Why did you subdivide the images? How did you pick the dividing point?
Once again, my complements!
Keith
PostPosted: Wed Dec 06, 2017 5:10 pm    Post subject: Reply with quote
Very encouraging:).
Being picky, there is a fuzzy patch about 3/4 the way up each "horn". Any idea why?
PostPosted: Wed Dec 06, 2017 5:59 pm    Post subject: Reply with quote
Stephen,
Great work!! Only 2nd attempt....amazing results!!!
Mike[/b]
stephenlewis
PostPosted: Wed Dec 06, 2017 7:01 pm    Post subject: Reply with quote
Keith
Hi Keith
After a lot of trial and error with my first effort I found that this method resulted in fewer artefacts. The split into three again came from experimenting as I found that anymore than 35 or so images also produced artefacts. I think that generally the fewer images stacked the fewer problems.
Stephen.
stephenlewis
PostPosted: Wed Dec 06, 2017 7:05 pm    Post subject: Reply with quote
ChrisR wrote:
Very encouraging:).
Hi Chris.
I think that my starting point for focus wasn’t accurate enough, and the two out of focus areas are a result of operator error !
Stephen.
PostPosted: Wed Dec 06, 2017 7:11 pm    Post subject: Reply with quote
OK we'll let you off (for now Wink)
This is part way through the depth though, isn't it? ? Or, when you said 3 stacks, did you have to back off coarse focus and restart fine, or something?
I'm just wondering if you were doing someting "odd".
Sumguy01
PostPosted: Wed Dec 06, 2017 9:24 pm    Post subject: Reply with quote
Very Happy Very nice.
Thanks for sharing.
