www.photomacrography.net :: View topic - New to Micro, need advice
Jwcollect
PostPosted: Mon Dec 04, 2017 4:41 pm    Post subject: New to Micro, need advice Reply with quote
I have a Nikon 10x Plan Achromat Infinity Objective attached to the from of my Nikon D600 and a 70-200mm telephoto lenses and I'm having trouble focusing.
I know I may get some vignetting but will this setup work?
Do I need to be right on top of the subject?
Any special setting I need on the camera our lenses?
Thank you
PostPosted: Mon Dec 04, 2017 4:55 pm    Post subject: Reply with quote
Yes, this should work. Vignetting will be minimized, and the objective will give its rated magnification, when the telephoto is set to 200 mm. The telephoto should be focused at infinity and set to shoot at its widest aperture. The focused subject will be just a few mm in front of the objective. If the objective has some notation like "WD 10.5", then that means "working distance 10.5 mm", and that will be the distance from tip of the objective to the focused subject.
Jwcollect
PostPosted: Mon Dec 04, 2017 5:24 pm    Post subject: Reply with quote
Thanks Rik. Just looked, yes it does have a the 10.5mm working distance.
PostPosted: Tue Dec 05, 2017 3:14 am    Post subject: Re: New to Micro, need advice Reply with quote
Jwcollect wrote:
...and I'm having trouble focusing.
What kind of trouble?
Be aware that the depth of focus is really small and because the small effective aperture you need lots of light. Both factors make focusing with the optical viewfinder somewhat difficult, with a steady setup and good illumination it's easier and also it is with camera live view image. Of course as Rik said set the camera to M at its widest aperture and disable AF. Focusing is done changing in small steps the distance between the subject and the objective tip.
Jwcollect
PostPosted: Tue Dec 05, 2017 5:56 am    Post subject: Reply with quote
Thank you.
