www.photomacrography.net :: View topic - Unknown electronic component
harisA
PostPosted: Mon Dec 04, 2017 10:03 am    Post subject: Unknown electronic component Reply with quote
This came from an electronic device's motherboard. Hope someone can identifu it.
PostPosted: Thu Dec 07, 2017 10:22 am    Post subject: Reply with quote
Very nice photo
PostPosted: Thu Dec 07, 2017 12:24 pm    Post subject: Reply with quote
That's a very interesting marking technique! Looks like a welding track, complete with discoloration. Some sort of electric arc process?
I do not recognize the component.
genera
PostPosted: Thu Dec 07, 2017 3:01 pm    Post subject: Reply with quote
If it's off a PC motherboard it may be a crystal oscillator. Just a wild guess.
The weld around the perimeter was possibly done with a laser welder or a TIG welder in a vacuum or inert atmosphere. I say that because there's no heat discoloration. The ID markings were probably done with a laser welder but in a normal atmosphere resulting in oxidation from the heat.
-Gene
PostPosted: Thu Dec 07, 2017 3:33 pm    Post subject: Reply with quote
Can you post a picture of the entire component? Doesn't have to be a "quality" shot though. This could help identify it. BTW 26.0 is not a standard number you see on non-accurate components like typical resistors and capacitors which use 22 and 27.
harisA
PostPosted: Fri Dec 08, 2017 7:36 am    Post subject: Reply with quote
Here is some additional information. Initial photo was taken with 10x objective so approx.. dimensions of the component are 1.9mmx2.5mm.
This came from mobile phone motherboard. Here are some 5x images.
1)Bright field
2)Bright field with cross polarizers (focus on board plane reveals 4 wire connections)
3)Dark field
PostPosted: Fri Dec 08, 2017 1:05 pm    Post subject: Reply with quote
Looks like a crystal oscillator to me, probably 26.0 MHz.
Smokedaddy
PostPosted: Fri Dec 08, 2017 5:21 pm    Post subject: Reply with quote
Interesting.
PostPosted: Sat Dec 09, 2017 8:09 am    Post subject: Reply with quote
Note that apparently only 3 electrical connections are used, the lower right "pad" doesn't seem to be connected. This would follow a simple oscillator, since only +Vcc, Ground and the output are needed.
