Pardon the desolate condition of the subject and the lack of diffusion although using a ping pong ball... This is just a feasability study and a test of the UMPLANFL 5x.
https://i.imgur.com/aGgWtKU.mp4
https://i.imgur.com/9a0vKxd.mp4
Best regards,
Michael
Fly animation
Yes, the UMPLANFL is at 0.15 NA, but this stack consist of roughly 250 images, way enough for a smooth rotation. Quality degrades a bit towards the outer ends, which are -7° to 7°, but it's acceptable. And of course it's a straight PMax stack, no way to get such a result in DMap, there's always a hell of jittering around the edges.
edit: Forgot to mention that the retime also smoothens out the frame to frame brightness differences / jitter. Here are the non retimed versions:
https://imgur.com/Y7PG3En
https://imgur.com/u6bH9v4
The normal units for shift in Zerene Stacker are percent (%), not degrees (°). Do you mean percent, or are you working with degrees as explained at https://zerenesystems.com/cms/stacker/d ... wing_angle ?
Either way, I guess it does make sense, now that I run the numbers. NA 0.15 means that the entrance pupil is +-15%, equal to +-8.5 degrees. So yes, the shifts that you're using do still lie within the cone of light that was actually captured in the stack, which is my usual guideline for what's required.
But the result still violates my intuition, in a good way. Nice work!
BTW, are these normal PMax? I have not tested, but it's conceivable that UDR PMax would have less variation in brightness.
- carlos.uruguay
