www.photomacrography.net :: View topic - Strobe speed
Strobe speed
PostPosted: Sun Nov 19, 2017 12:38 pm    Post subject: Strobe speed Reply with quote
Just did a quick strobe test with the Nikon D850 using CH mode at 7 frames per second. This was an RF link with Adorama Flashpoint Rapid 600 studio strobe. It kept up at 1/4 power for about ~8 shots before missing, I was shooting >10 frames, and at 1/8 it kept up without a missed output.
The XPLOR 600 (AD600) using AC adapter was good as well, it couldn't quite keep up at 1/4, but only missed a few at 1/8 and didn't miss any at 1/16.
The Studio Strobe 300 AC couldn't keep up at 1/16, this was as low as it can go on power.
Anyway, for those folks that want to blast thru a stacking session the Rapid 600 Studio Strobe can probably keep up, and the XPLOR might work also.
zzffnn
PostPosted: Sun Nov 19, 2017 1:31 pm    Post subject: Reply with quote
Thank you very much for sharing this information, Mike.
So your test shows that Rapid 600 can keep up with 7 exposures per second, at 1/8 power. But it is much faster, at less power, I assume?
I looked into Rapid 600 and found the following confusing description about flash speed at Adorama:
"......under Multiflash Mode, where the stroboscopic frequency can reach 99 flashes per second. The High-Speed Flash Mode has controllable flash duration is so rapid, it is possible to arrest action at 1/19606s, with up to 10 exposures per second, or take it easy with 'slow' duration at a spectral rich 1/190s burst."
Can it really produce 99 fires per second, at lowest possible power?
I think about 30 fires per second will be more than good enough for me. And I don't usually require consistent color/power. Is the Rapid 600 or XPLOR the best bang for the buck?
I don't know about D850 or its CH (continuous high) mode. Is that mode using electronic shutter?
PostPosted: Sun Nov 19, 2017 2:04 pm    Post subject: Reply with quote
Yes, the Rapid can keep up at 7FPS at 1/8 power and almost for 1/4 power except it will miss an exposure after 8~9 frames. The Multi Mode each flash is not being individually triggered by the camera, just a fast burst of flash at up to 99 per second.
Both the Rapid 600 & XPLOR are great studio strobes, the XPLOR is battery powered & has the head extension option. The Rapid has a faster recharge, faster optical burst and has a special color control mode.
I use the Studio 300 AC for many of my macro sessions, these are not fast, nor battery powered, but are hard to beat for the price ($100 on sale at Adorama). Also they have a 2% uniformity spec, which may be important for macro stacking certain subjects.
zzffnn
PostPosted: Sun Nov 19, 2017 2:20 pm    Post subject: Reply with quote
Thanks, Mike.
So what is the fastest possible firing speed of Studio 300 AC? That price is great indeed
PostPosted: Sun Nov 19, 2017 4:35 pm    Post subject: Reply with quote
I don't know but would estimate something like once or twice per second at lowest power 1/16 and once every 2 seconds at full power. Certainly not good for recycle speed.
