www.photomacrography.net :: View topic - Flange Mod for use with Nikon 1.4TC
PostPosted: Tue Nov 28, 2017 5:26 pm    Post subject: Reply with quote
Thanks Rik!!
I had used the incorrect lens F# instead of the correct Effective F#, (1+1)*2.8 for F, thus the larger NA by 2 times!! Should have realized that a 0.179 NA for an F 2.8 lens at 1X was not realistic, my bad!!
My sincere apologies to harisA about the incorrect NA. So one only needs greater than a 250MP full frame sensor to out-resolve the PN105 instead of the > 950MP sensor!
PostPosted: Tue Nov 28, 2017 6:17 pm    Post subject: Reply with quote
I'm almost there. I have made a device to to move my MFT sensor across an aerial image in the x-y direction, mounted on a WeMacro rail for stacking in the z direction. In hi-res mode I get 80 Mp (really about 50Mp worth of resolution), times 4 to cover the whole area of a FF sensor, for 200-240Mp.
www.loujost.com
harisA
PostPosted: Thu Nov 30, 2017 2:54 am    Post subject: Reply with quote
Thank you Rik for clearing this.It's obvious that a low magnification microscope objective (1x-2x) has no lack compared with a macro lens at same magnification. Not to mention the small image circle these objectives always have.
PostPosted: Sat Dec 02, 2017 12:34 pm    Post subject: PN105 with 1.7TC Reply with quote
Found an older Nikon TC-17E II that I used the modded F fount adapter with the Nikkor PN105 F2.8A for another test with the D800E. Used the same old 6" silicon wafer as a test subject for this 1.7X test. You can see more CA at the edges and also loss of sharpness as expected.
Not sure how this stacks up against the best lenses around 2X, but at least it works and produces an acceptable result IMO. I won't be running any comparison tests around 2X since I have nothing respectable to compare with this combo.
https://nis.nikonimagespace.com/html/myphoto/en/view/albums/albums/0l5sw6500000n9lpg8o106h7vv2/photos?sortBy=shotDate&sortOrder=asc
PostPosted: Sat Dec 02, 2017 2:32 pm    Post subject: Reply with quote
Right, 1x-2x microscope objectives really have nothing to recommend them, unless you need to work at 1x-2x within the frame of a microscope that the objective fits.
For a microscopist, 1x-2x objectives can be very useful for looking at large subjects.
But anybody else will do better with an ordinary lens, which is simpler to design and build, so works better at same or lower price.
harisA
PostPosted: Sun Dec 03, 2017 2:50 am    Post subject: Reply with quote
Mike the link is not working for me giving a server error message.
PostPosted: Sun Dec 03, 2017 5:55 am    Post subject: Reply with quote
I just used these and it worked?
https://nis.nikonimagespace.com/html/myphoto/en/view/albums/albums/0l5sw6500000n9lpg8o106h7vv2/photos/03ha54n00000neepa90d0000p7w_500_0007_000?sortBy=shotDate&sortOrder=asc
PostPosted: Sun Dec 03, 2017 6:06 am    Post subject: Reply with quote
Here's the link for the Nikkor PN-105mm on D800E at 1X:
https://nis.nikonimagespace.com/html/myphoto/en/view/all_photos/photos/03ha54n00000neepa90d0000p7w_500_0005_000
at 1.4X with the Nikon TC:
https://nis.nikonimagespace.com/html/myphoto/en/view/all_photos/photos/03ha54n00000neepa90d0000p7w_500_0006_000
and 1.7X with the Nikon TC:
https://nis.nikonimagespace.com/html/myphoto/en/view/all_photos/photos/03ha54n00000neepa90d0000p7w_500_0007_000
As you can see the CA gets worse, as does the corner sharpness, with the TC and degrades with TC magnification.
PostPosted: Sun Dec 03, 2017 6:14 am    Post subject: Reply with quote
All give "Server Error" or "Please Log In Again" , depending on browser.
PostPosted: Sun Dec 03, 2017 6:33 am    Post subject: Reply with quote
Same for me now.
www.loujost.com
PostPosted: Sun Dec 03, 2017 6:44 am    Post subject: Reply with quote
This works for me from my Mac Pro, I'll try my MacBook Pro laptop.
From my MBP it say's I need to sign up or log in from each. So maybe you need to sign up, which is free.
I logged in from my MBP and it works, so looks as if you have to log in to view images. This may be different policy since my links earlier in this thread which evidently did not require a log in to view.
PostPosted: Sun Dec 03, 2017 7:00 am    Post subject: Reply with quote
I can confirm that I didn't need to log in to see your earlier linked image.
www.loujost.com
PostPosted: Sun Dec 03, 2017 8:24 am    Post subject: Reply with quote
Think the Nikon policy must have changed since I first posted.
PostPosted: Sun Dec 03, 2017 1:31 pm    Post subject: Reply with quote
Here's another try with different approach, also including 2X version with old Tamron 2X TC.
With Tamron 2X TC
https://nis.nikonimagespace.com/html/guest/detail.html?g=5xCFhBeto_SZNLlFwfJrtq8BMuZ1cHP-VOWqtI1SvWrRz7FEIqwgOyJ9zuSZkZMV5GDJJmfsIdM4z6sAtrPhKc34nO31VxkGabIh2gb7LztLYhIr9fox_6mqBbSgPe3iA5XIoBLwptE
With no TC @ 1X
https://nis.nikonimagespace.com/html/guest/detail.html?g=5xCFhBeto_SZNLlFwfJrtq8BMuZ1cHP-VOWqtI1SvWrRz7FEIqwgOyJ9zuSZkZMV5GDJJmfsIdM4z6sAtrPhKTyoq6dA2tnHabIh2gb7LztLYhIr9fox_6mqBbSgPe3iA5XIoBLwptE
With Nikon 1.4TC @ 1,4X
https://nis.nikonimagespace.com/html/guest/detail.html?g=5xCFhBeto_SZNLlFwfJrtq8BMuZ1cHP-VOWqtI1SvWrRz7FEIqwgOyJ9zuSZkZMV5GDJJmfsIdM4z6sAtrPhKZqw3G-FHVJCabIh2gb7LztLYhIr9fox_6mqBbSgPe3iA5XIoBLwptE
With Nikon 1.7TC
https://nis.nikonimagespace.com/html/guest/detail.html?g=5xCFhBeto_SZNLlFwfJrtq8BMuZ1cHP-VOWqtI1SvWrRz7FEIqwgOyJ9zuSZkZMV5GDJJmfsIdM4z6sAtrPhKSGgabvaCVSeabIh2gb7LztLYhIr9fox_6mqBbSgPe3iA5XIoBLwptE
PostPosted: Sun Dec 03, 2017 1:35 pm    Post subject: Reply with quote
That works, and the 1.7 x image looks very clean, but though I can get it to fill my monitor screen, I cannot figure out how to zoom in to 100%.
www.loujost.com
Page 2 of 3
