www.photomacrography.net :: View topic - Microscope Objective Clarification
Goto page Previous  1, 2
Deanimator
PostPosted: Sat Nov 18, 2017 4:54 pm    Post subject: Reply with quote
Pau wrote:
Don't buy the 4 objectives set: they are inferior, see the difference with the Plan objective, and you only could profit for macro the 4X and 10X and both likely not very adequate for the task, they are entry level optics to work in cheap school grade microscopes
I'll stick with the single 4x finite.
I had read the review before it was reposted here, and was impressed. It seems like a very good value for them money.
PostPosted: Sat Nov 18, 2017 5:21 pm    Post subject: Reply with quote
The AmScope 4X finite is like a "Jewel in the rough" someone said!! The WeMacro 4X Infinite is also pretty good considering the cost. Saw a Nikon 200mm F4 Q in good shape go for $24 + $6 shipping yesterday, so if you can find a Canon equivalent, or as Chris mentioned the Raynox 150, you should be go to go either way, finite or infinite!!
Deanimator
PostPosted: Sat Nov 18, 2017 5:33 pm    Post subject: Reply with quote
I'll probably work up an infinite rig eventually.
I'm going to start with finite because it's easier and cheaper to start.
I just got shifted to the 9:00pm to 5:30am shift at work, so reading and indoor macro are about all I'll be doing for the foreseeable future.
Deanimator
PostPosted: Sun Nov 19, 2017 2:45 pm    Post subject: Reply with quote
I just ordered all of the finite gear (and a Foreman grill for my mother).
I got,
from Amazon:
  1. 4x Amscope objective
  2. two sets of M42 tubes
  3. EOS to M42 adapter
from eBay:
  1. M42 to RMS adapter
  2. M42 bellows
Working from 9:00pm to 5:30am for a 24/7 business doesn't afford me much opportunity for amusement. This stuff should occupy the leisure time I have.
Deanimator
PostPosted: Sun Nov 19, 2017 7:22 pm    Post subject: Reply with quote
ChrisR wrote:
Your zoom will be far from ideal, probably only working without vignetting at the 300mm end.
I've got an old Minolta 100-200 push-pull manual zoom lying around.
Would that work?
PostPosted: Mon Nov 20, 2017 4:49 am    Post subject: Reply with quote
That stands a better chance,( if you can adapt a Minolta to your camera Neutral ) because it's more to do with the construction of the lens when you pull away from the longes end, than the actual FL, which matters.
I have an old 80-200 Nikkor which only just vignettes on full frame.
If you have tubes already, you could look for that Sigma close-up diopter. It's 52mm both sides so relatively easy to adapt to. They're often pretty cheap. Our member Saul found them to be very good.
PostPosted: Mon Nov 20, 2017 6:23 am    Post subject: Reply with quote
For a Canon EOS Minolta SR-mount is a bad idea because its Flange focal distance of 43.50 mm vs 44mm of Canon EF mount so if you find the adapter it will not focus to infinite or it will be bundled with a bad quality lens to do so, bad option in both cases
Deanimator
PostPosted: Mon Nov 20, 2017 8:19 am    Post subject: Reply with quote
It's an MD mount. It dates back to 1981 when I used it to take pictures of North Korean guardposts.
PostPosted: Mon Nov 20, 2017 10:17 am    Post subject: Reply with quote
SR and MD are different versions of the same mount, what I said still applies
https://en.wikipedia.org/wiki/Minolta_SR-mount
Deanimator
PostPosted: Mon Nov 20, 2017 10:20 am    Post subject: Reply with quote
Thanks.
Deanimator
PostPosted: Wed Nov 22, 2017 5:25 pm    Post subject: Reply with quote
The following have arrived:
  • M42 bellows
  • EOS to M42 adapter
  • Amscope 4x objective.
I'm still waiting on the RMS to M42 adapter and the M42 extension tubes.
Deanimator
PostPosted: Fri Nov 24, 2017 3:31 pm    Post subject: Reply with quote
I got the two M42 extension tube sets and the M42 to RMS adapter today.
Just for giggles, I did a live view test with objective on the end of the two sets of M42 extension tubes.
For a subject I used a 148gr. .38 Special wadcutter round stood on its nose. The rim looked like the edge on view of a manhole cover.
I think I'm going to have a lot of fun with this.
Page 2 of 2
