www.photomacrography.net :: View topic - Technique for quickly framing subject at high mag.
cube-tube
PostPosted: Tue Nov 14, 2017 6:42 pm    Post subject: Technique for quickly framing subject at high mag. Reply with quote
I came up with a very useful technique for framing a subject that I thought I should share.
If you are using a DSLR, you can shine a laser pointer through the viewfinder. The laser will appear as a dot on the subject in the exact center of the frame. When the subject is in focus, the laser will be focused to a sharp dot on the subject. When out of focus, the dot grows in diameter.
It is a very quick and easy way to approximate framing and focus before making fine adjustments with live-view. It is much quicker and less cumbersome than guessing and checking by adjusting the subject and then checking live view, especially when there is a specific location on the subject that you want to photograph.
I encourage you to try it!
PostPosted: Tue Nov 14, 2017 8:54 pm    Post subject: Reply with quote
A sighting laser is a big convenience in my workflow as well. Very Happy
Demonstration and instructions can be found in this post: Laser aiming and focus in photomacrography.
cube-tube
PostPosted: Wed Nov 15, 2017 12:14 pm    Post subject: Reply with quote
That is so cool!
JW
PostPosted: Wed Nov 15, 2017 3:16 pm    Post subject: Reply with quote
I've been doing this for years, but with a pin-point LED designed to illuminate gems and cut stones in display cases - works like a charm. But for me, I need to turn down the room lights to see the spot.
It's not what you look at that matters, it's what you see - Henry David Thoreau
