www.photomacrography.net :: View topic - Macro Focusing Rails
Goto page Previous  1, 2
Deanimator
PostPosted: Sat Nov 11, 2017 11:07 am    Post subject: Reply with quote
ray_parkhurst wrote:
Once you start doing focus stacking, especially if you increase in magnification, you will likely soon tire of the manual adjustments and will be looking for an automated solution. With respect to your statements about not wanting to go automated right away, I can only suggest to minimize your expenditures for the manual focus rail by buying an inexpensive one that will adequately do your initial work at 1:1 but doesn't offer the precision required for higher magnifications. I would still concentrate on getting a worm gear driven rail, rather than a rack and pinion type, since they are more precise, especially if they have a large-ish knob.
The above is excellent advice. I know from experience.
I wouldn't spend a lot of money on a manual rail, as one that's really precise and repeatable is going to approach or exceed the cost of something like a Wemacro.
At high magnifications, stacking with a manual rail is going to get VERY tedious. With a manual rail cheaper than a Wemacro, it's going to become maddening.
I used a cheap Chinese rail from eBay for a few years, mostly for single images. It was great for fine focusing for single shots. On those few occasions when I tried to do stacking with it, it was an exercise in frustration.
An alternative to (and an intermediate step towards) an automated rail is automated tethering software like DSLR Controller (for Canon and Android). The software is usually very reasonably priced, and allows you (with the appropriate autofocus lens) to do focus stacking with an inexpensive rail or no rail at all. There are a number of such apps, for PCs (Windows, Linux, and Apple), and for phones and tablets (Android and iPhone).
If it were me, I wouldn't spend more than about $50usd on a manual rail. I'd buy tethering software and save my money for a Wemacro or Stackshot.
lothman
PostPosted: Sat Nov 11, 2017 12:18 pm    Post subject: Reply with quote
This one looks to have a fairly fine pitch screw, and like the Hejnars has very nice feature of adjustments from each end.
https://www.ebay.com/itm/MENGS-W-160-Macro-Focusing-Rail-For-DSLR-Camera-Compatible-with-Arca-Swiss/352166514613?hash=item51fec28fb5:g:bbwAAOSwzilZvMCD
I got this via aliexpress and it is much worse than the Ishoot. The rail wobbles and can not be tightened. It also has no quick release on the worm gear so you have to screw it all the way up and down.
ray_parkhurst
PostPosted: Sat Nov 11, 2017 12:45 pm    Post subject: Reply with quote
Would have been nice to know ahead of my order, but I'll give it a go nevertheless.
Mannheim62
PostPosted: Fri Nov 17, 2017 7:29 am    Post subject: Reply with quote
I'd like to thank everyone for your advise and suggestions. It seems I have a lot more to consider than I originally thought. Hopefully I'll come to a decision soon.
Thanks again,
ray_parkhurst
PostPosted: Fri Nov 17, 2017 8:56 pm    Post subject: Reply with quote
I have received both of the rails I linked to earlier. They are both abysmal. Both have significant backlash, and bearing wobble. I hope the iShoot rail is better than these.
That said, I see potential in the Mengs rail, but it will take some work to achieve. I'll see if I have time to give it a try. Meantime, find a better rail.
Mannheim62
PostPosted: Fri Nov 17, 2017 9:16 pm    Post subject: Reply with quote
Sorry to hear those rails didn't work out.
ray_parkhurst
PostPosted: Sat Nov 18, 2017 10:35 am    Post subject: Reply with quote
No worries, though it does create a new project for me. I plan to modify the Mengs to see if I can make a decent vertical rail out of it. All my systems are vertical, since it's convenient/desirable to place a coin flat on the imaging stage. The weight of the camera (if camera is moved) or stage (if camera is held fixed) holds the screw tight against the upward force of the screw, so this essentially eliminates screw backlash. Wobble remains the biggest issue for vertical setups, so I'm looking to fix that on the Mengs rail. Turns out the rail has a nice arrangement of precision 4mm optical rods, one on each side of the screw. I think that linear bearings can be added to make the stage stable.
So bottom line the Mengs project is to add linear bearings. If the stability is good then add a stepper on one end, leaving the other end with larger screw knob.
Mannheim62
PostPosted: Sun Nov 19, 2017 8:23 am    Post subject: Reply with quote
That sounds like one heck of a project ... best of luck !!!
Page 2 of 2
