www.photomacrography.net :: View topic - 4X Test - Any Advice?
Goto page 1, 2, 3  Next
RobertOToole
PostPosted: Mon Nov 06, 2017 11:29 pm    Post subject: 4X Test - Any Advice? Reply with quote
Later this month or early next month I plan to run a comparison at 4X to find the winners and losers in the stack of 4X objectives I own.
It would be great to get some input with ideas and suggestions before I start the test.
For the objectives I am planning on running the test on a 24MP APS-C Sony body. Planning on running this in 2-3 stages. Test subject is going to be a Silicon wafer.
Low End Objectives
$17 Amscope 4X/0.1
Nikon Plan CFI 4X/0.13 knurled ring
Nikon BE Plan 4X/0.1
Nikon E Plan 4X/0.1
Nikon Plan 4X/0.1 gold barrel
LaboMed Semi Plan 4X/0.1
High End Objectives
Nikon Plan Fluor 4X/0.13
Nikon Plan APO 4X/0.16 finite (old CF type)
Nikon Plan APO 4X/0.20 infinity nano crystal
Nikon Plan APO 4X/0.20 finite (new type)
Nikon S Fluor 4x /0.20
Nikon MM 3X
Nikon MM 5X
Lenses
Canon MPE65
Canon MP20
Canon MP35
Extras
I also have these laying around that I can throw on the 4X setup or run these in a separate comparison.
Schneider Componon 28mm f/4 old black barrel
Schneider Componon 28mm f/4 Plastic Enlarger barrel
Schneider Componon 35mm f/4 Plastic Enlarger barrel
Schneider Componon 28mm f/2.8 V-mount
Schneider Componon 45mm f/4 V-mount
Suggestions, ideas, recommendations?
BTW, I have seen these two very good 4X tests posted here in the past.
Shootout at 4-6x
http://www.photomacrography.net/forum/viewtopic.php?t=19252
and
4x lenses and objectives shootout
http://www.photomacrography.net/forum/viewtopic.php?t=22688
enricosavazzi
PostPosted: Tue Nov 07, 2017 3:25 am    Post subject: Reply with quote
Maybe it has already been done (in which case I would like to hear about it), but it might be interesting to test The Apo Componon HM 40 mm f/2.8 with the Apo Componon HM 45 mm f/4, since you already have the latter in your list.
lonepal
PostPosted: Tue Nov 07, 2017 5:06 am    Post subject: Reply with quote
Hi;
Could you add Lomo 3.7 to the list if you have one?
Thanks.
Regards.
Omer
zzffnn
PostPosted: Tue Nov 07, 2017 5:58 am    Post subject: Reply with quote
Robert,
I can loan you my LOMO 3.7x objective and will include enough stamps for shipping both ways, if you would test it and don't have it yet.
Please let me know, thank you. I suspect its corners won't be as good as the AmScope.
To reduce your effort, a ranking list or two would be good for me (I trust your judgement), you don't have to post many side by side photo comparisons. Or however you want to do it.
I can send you my Schneider Componon S 50mm F/2.8 as well, though I am not sure if you want it - you already have lots of Schneider's there.
JH
PostPosted: Tue Nov 07, 2017 6:37 am    Post subject: Reply with quote
I am looking forward to the results, especially the comparison between the Nikon 4x infinity lenses. One thought from my side is that the microscope objectives have high NA but a small image circle. On a microscope this is no problems because you use a eyepiece or a photo projection lens that enlarges the image. Therefore I use a tube lens or a teleconverter that matches the image circle with the camera sensor. For 4x on a FF sensor with a microscope objective the best sharpness option might be a 2x plan apo NA 0.1 lens and a 2x teleconverter. This will of course give you a short WD.
Best regards Jörgen Hellberg
Jörgen Hellberg, my webbsite www.hphoto.se
PostPosted: Tue Nov 07, 2017 8:09 am    Post subject: Reply with quote
Robert,
What about a Mitutoyo 5X Inf 200mm brought down to ~4X with a 160mm tube lens?
ray_parkhurst
PostPosted: Tue Nov 07, 2017 8:35 am    Post subject: Reply with quote
You may want also to test the 5xMM and 3xMM as Infinites.
The B&L 3.5x is a good one for low end testing.
I can loan you an Inspec.x L 4.0/105 3.5x if you don't have one, though pushing it to 4x will take quite the long extension.
And of course the 75PN. If only someone had one.
edited to add:
The Lomo Mikroplanars and Zeiss Mikrotars are good in this range.
Saul
PostPosted: Tue Nov 07, 2017 9:01 am    Post subject: Re: 4X Test - Any Advice? Reply with quote
RobertOToole wrote:
...Suggestions, ideas, recommendations?...
Schneider Componon 80mm f4
Saul
RobertOToole
PostPosted: Tue Nov 07, 2017 9:16 am    Post subject: Reply with quote
Hi Enrico,
Thats a good idea. Now I just need to find one for a good price.
I am thinking about splitting off the 28 to 45mm lens part of the test using the same target of course.
Thanks for the input.
RobertOToole
PostPosted: Tue Nov 07, 2017 9:18 am    Post subject: Reply with quote
zzffnn wrote:
Robert,
I can loan you my LOMO 3.7x objective and will include enough stamps for shipping both ways, if you would test it an don't have it yet.
Yes, please. I will PM you my details. Thanks.
Yes, I like the Componon S 50 a lot. I have two. One in V-mount and one in 39mm. Do you think the 50 would do well at 4X? I have not used it at the level, maybe 2-3 max.
RobertOToole
PostPosted: Tue Nov 07, 2017 9:22 am    Post subject: Reply with quote
Thanks for the idea.
I might do that as a side-project add-on since I have never tried a objective+T/C myself.
Thanks for the input Jörgen.
RobertOToole
PostPosted: Tue Nov 07, 2017 9:28 am    Post subject: Reply with quote
mawyatt wrote:
Robert,
Hi Mike,
I was going to try to stay away from the Mity, but I do have a 4X. What is a good 160mm tube lens? I have a Raynox 6x, thats 170mm, that would be what 4.25x?
zzffnn
PostPosted: Tue Nov 07, 2017 9:29 am    Post subject: Reply with quote
Robert,
I was told that the Schneider Componon S 50mm F/2.8 may not work as well at 4x or above and that it is sharp at around F/4. Though I am not positive.
I have not done any test myself and don't have the skills to do it properly either.
I will send you just the LOMO 3.7x.
RobertOToole
PostPosted: Tue Nov 07, 2017 9:33 am    Post subject: Reply with quote
edited to add:
Thanks for the all of the input Ray, I appreciate it.
Will let you know.
Oh yes, the super rare 75PN! Have you seen a single one show itself in the wild ?
If the 4X test results come out half as well as your 4-6X test did Ray, I will be happy.
RobertOToole
PostPosted: Tue Nov 07, 2017 9:35 am    Post subject: Re: 4X Test - Any Advice? Reply with quote
Thanks Saul.
Have you tried it at the high mag?
Page 1 of 3
