www.photomacrography.net :: View topic - Camera storage - Drybox advice
Goto page Previous  1, 2
PostPosted: Sat Oct 14, 2017 1:50 pm    Post subject: Reply with quote
Quote:
a couple of low watt bulbs in there
It really doesn't take much. You don't want to bake the stuff, just make it a few degrees above ambient and you won't get condensation, because you're well above the Dew Point, & the RH will be low.
Air movement and daylight are good, to help stop spores growing, though obviously fresh air ingress gives you more air to process.
CaCl is effective as a dehumidifier too - as sold in "Poundland"!
PostPosted: Sat Oct 14, 2017 2:14 pm    Post subject: Reply with quote
But make sure you get indicator dessicant. Otherwise you won't know when it is dead. And I get the feeling you may not realize how quickly it dies.
www.loujost.com
stormfoxy
PostPosted: Sat Oct 14, 2017 5:36 pm    Post subject: Reply with quote
Lou Jost wrote:
If you go on the sealed-box route, make sure you use indicator dessicant that changes color when full of water. Most people don't realize how fast dessicant becomes saturated.
Will do.
I have a few questions about using bulbs in a cabinet if you don't mind.
- what material of cabinet is best ie wood, metal?
- Should the cabinet be open or closed?
- Do you leave the bulbs on constantly or turn them off?
PostPosted: Sat Oct 14, 2017 7:17 pm    Post subject: Reply with quote
You leave the bulbs constantly on. Low wattage incandescent bulbs, not fluorescent or LED.
You want the cabinet to be very slightly vented.
Wood is easier, metal is less likely to burn. In the past I've made them out of big floor tiles or wall tiles, made into a cube with silicone, with the top just resting there.
www.loujost.com
Page 2 of 2
