www.photomacrography.net :: View topic - PN105 Wafer Image
PN105 Wafer Image
PostPosted: Mon Oct 02, 2017 5:10 pm    Post subject: PN105 Wafer Image Reply with quote
Here's a couple images with my new to me Printing Nikkor PN105mm F2.8A (thanks Ray). I used a Wemacro Vertical Stand with a Nikon D800E and PB6 Bellows. Focus rail is a modified (MJKZZ kit) THK KR20 controlled by Wemacro controller. The subject is a old 6" silicon wafer apparently with some very large test chips.
This image is a single image from the stack shot at ~1X.
Lighting was from a 8" by 3" by 9" cone made from $ Store stiff white paper and 3 strobes. I had to use hp inkjet paper as a white balance as the cheap paper cone had a ugly yellow cast. I'll be getting some better material for the cone soon to help improve the lighting....and working on the other aspects of the setup.
Anyway, think this is a good start for the PN105 Very Happy
BTW these look much better in full resolution.
RobertOToole
PostPosted: Mon Nov 06, 2017 9:36 pm    Post subject: Reply with quote
Top image looks great Mike.
For some reason the bottom one looks soft, I am sure the original is not judging by the other images I have seen of yours.
Great work on the lighting!
PostPosted: Tue Nov 07, 2017 6:55 am    Post subject: Reply with quote
Robert,
I hadn't noticed, but you are right it does look soft. Probably caused by my downsizing. As you say the originals are much sharper.
Looking forward to your 4X test.
BTW did you ever make it to Clearwater?
