Video of the process crystallization of citric acid. (Time lapse)
Video:
https://youtu.be/ybiXEDFwMwU
Francisco
Citric acid. Crystallization
- carlos.uruguay
That's really cool looking Francisco. Makes me want to try to do something like that. I'm with Smokedaddy in wanting to know more about how you did it. Maybe it's a "trade secret," but if not, what solution did you start with and how long did it take for the process to complete? Thanks in advance for the information.
Thanks for your comments
Smokedaddy - billporter1456, the procedure is very simple.
Dissolve citric acid in water or alcohol. Put a drop on the slide and wait for it to evaporate producing crystallization.
Depending on the solvent (water or alcohol), temperature and degree of saturation we will get different types of "micro crystals".
In the video, the solvent is alcohol.
In this other video whose solvent is water, crystallization is somewhat different (larger crystals)
https://youtu.be/9Zbm1nV-mC8
Thanks for that information. I may give it a try. Your results are impressive.fpelectronica wrote:Thanks for your comments
