www.photomacrography.net :: View topic - Wanted phase contrast objectives
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Equipment Exchange
MicroscopeM
PostPosted: Thu Jul 06, 2017 8:21 pm    Post subject: Wanted phase contrast objectives Reply with quote
Hello the forum, I need to buy a 40x and 100x phase contrast objectives. They are to fit a Zeiss Jennamed 2 which is an infinity corrected machine.
Could I use Olympus or Nikon infinity phase objectives instead of Zeiss infinity objectives?
Thanks for your time.
MicroscopeM
PostPosted: Fri Jul 07, 2017 12:23 am    Post subject: Reply with quote
It can't be said a priori without testing: the condenser and objective phase rings must be matched (same optical size and conjugate optical plane) and there is quite a variation between makers and models, so in principle no. Maybe in some cases they will match but buying objectives just to test may be an expensive way.
MicroscopeM
PostPosted: Sat Jul 08, 2017 8:14 pm    Post subject: Reply with quote
Thank you for your reply Pau.
If I purchased Zeiss infinity objectives then they should be ok or is it possible that objectives are actual make and model restricted?
I agree with you it would be easy to waste several hundred dollars especially since I have never touched a microscope before.
I may just have to buy an AmScope and be done with it.
Thanks again.
M
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Equipment Exchange All times are GMT - 7 Hours
