www.photomacrography.net :: View topic - Lens resolving power - can I show Tiff files
LVF
PostPosted: Sun Jun 11, 2017 4:44 pm    Post subject: Lens resolving power - can I show Tiff files Reply with quote
I am photographing a resolution chart with several lens, teleconverters, and extension tubes. I am doing this at varying lens apertures. I believe that Tiff files will show the difference between apertures better than the required posting Jpg files. Is it possible to post Tiff files?
Leon
PostPosted: Sun Jun 11, 2017 6:31 pm    Post subject: Re: Lens resolving power - can I show Tiff files Reply with quote
This forum's upload software does not allow TIFF. Most browsers cannot display TIFF either.
I suggest instead using PNG. That format is supported by the upload software, and by browsers, and has the same lossless properties as TIFF.
Be aware, however, that you will still be subject to the 300 KB limit on file length. Depending on image content, that may limit the pixel dimensions of your PNG image to be less than you would like. In that case you will have to choose between the limited pixel dimensions of PNG, or the least compression of JPEG that will let you fit the number of pixels that you want into 300 KB.
That's a common belief, but when careful comparisons are done, it seldom turns out to actually be the case. Resolution charts compress nicely with JPG because they are mostly composed of large featureless regions separated by sparse edges. As a result they generally tolerate a high quality setting (light compression), which preserves even the edges quite well. The biggest problem for JPEG is with images that are richly detailed all over the image, almost the antithesis of a resolution chart.
LVF
PostPosted: Mon Jun 12, 2017 9:50 am    Post subject: Reply with quote
Thank you. I will explorer using Png. However, I guess the use of Jpg in this case is O.K.
Leon
