View previous topic :: View next topic |
Author |
Message |
Saul
Joined: 31 Jan 2011 Posts: 1057 Location: Naperville, IL USA
Back to top |
Saul
Back to top |
aspolat
Back to top |
Saul
Posted: Sat Mar 24, 2018 1:21 pm Post subject: |
Hi Samil,
aspolat wrote: | ... i can control the stage with wemacro controller... |
There are some possible connection conversions from 5 to 4 wires, but I would contact William from WeMacro, he knows better internals of his design , can it be done. Worst case scenario - you can use 4 wire stepper with some simple 3d printed adapter (or something simpler), I done that in my Del-Tron setup.
Quote: | ... have to use microstep driver (8-16-32 even 64 microsteps)... |
If I remember correctly, WeMacro has up to 32. Looking at the rail specs, you should be OK for 50x. I'm not big fan of the horizontal setup (using in the field mostly or for some big specimens which I cannot fit/position on the my vertical setup)
Quote: | ...You have really big experience about it ... |
It is not true My experience is based on others experience/almighty Google/trial&error  _________________ Saul
Studio, horizontal and field setups |
Back to top |
aspolat
Posted: Sat Mar 24, 2018 3:42 pm Post subject: |
Hello again Saul,
Thank you for quick and comprehensive reply, appreciated.
I looked some CNC forum today, and i read something about vexta motors. They are 5 phase motors. You need special drivers for drive 5 phase motors, and they are very different then 2 phase motors.
Maybe we can control unipolar stepper( 5-6 wires and two phases) motor with some basic microchip as like L298N H Bridge. Even if we can modify wemacro controller for drive it.
But, I don't think so wemacro controller can drive 5 phase vexta motor. Completelly different system.
I think best idea is replace the vexta motor with NEMA 11 200 step/rev. (i guess dimension is almost same) standart 2 phase 4 wire motor as like your Del-TRON design. Thus easly can control with wemacro controller. As like you said
And i agree with you, the best option for 20X upper magnification is vertical setup. But i am so mobile and i could have not set yet.
Thank you again
Best Regards... _________________ Samil POLAT
Flickr |
Back to top |
