I'm testing out a Macro Varon lens and, while I'm very pleased with the results, I'm a little confused.
The following image was taken with the lens extended ~102 mm away from my fuji xt-1. For a larger version, click https://www.flickr.com/photos/150316026 ... res/rJHq4T
The lens has a focal length of 85.1 mm, so I expected the magnification to be around 1.2 x. I took an image of a ruler using the same settings as above and this is what was in focus.
My camera's sensor is 23.6 mm long, so the lens appears to be focusing at ~0.5x. Why is this given the distance from lens to sensor?
Thanks!
Macro varon test and confusion
Re: Macro varon test and confusion
At http://www.schneiderkreuznach.com/filea ... 4.5-85.pdf , the table on page 2/2 says that 0.5X happens when the "flange-to-image" distance is 106 mm.Davids wrote:The following image was taken with the lens extended ~102 mm away from my fuji xt-1.
How does that compare with whatever you're measuring as 102 mm?
Excellent.
So then, to add a bit of theory that I'm guessing you were missing...
The formula that magnification = extension/focal_length only applies when the "extension" is measured as the additional extension beyond infinity focus.
It is a specialization of the more general formula that added_magnification = added_extension/focal_length, working from a base of infinity focus where magnification = 0.
But the Macro Varon is a "short barrel" lens that requires some extension just to reach infinity focus in the first place.
Working backward, that base extension would be about 106-85.1*0.5 = 63.45 mm. From that you can reproduce most of the other numbers in the PDF to within a mm. The 2X number is several mm off. If that's not a measurement error, then I'm guessing it's due to a side effect of the beta adjustment.
- Charles Krebs
Once again, thank you both for the input! Here's a second go with the lens. This is a seed pod of Carolina Cranesbill at around 1.1x. You can see a larger version here: https://flic.kr/p/TgupUJ
