www.photomacrography.net :: View topic - With the help of this forum, my photos are getting better
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Community Members and Friends
timmymac
PostPosted: Wed May 03, 2017 5:21 am    Post subject: With the help of this forum, my photos are getting better Reply with quote
I'm new to this photomacrography niche, and still learning. And the learning curve is very steep!
Recently while cleaning out my garage, I found some Zeiss objectives from a decommissioned machine. Trying to use the 10x objective with my Panasonic GX8 m4/3 camera led me down the rabbit hole of focus stacking (with Helicoid Focus) and this site. Unfortunately, the m4/3 lenses I have behave poorly as tube lenses. I ordered the Nikkor 200mm F4 Non-AI lens, and I'm impatiently waiting for it's arrival.
I went to 8020.net (an awesome site) and ordered up the parts to make a vibration resistant vertical stacking frame (I'll post assembly pictures when the parts arrive). My current configuration is very shakey at best. Those parts should arrive in a week or so.
I've recently received the EL-Nikkor 50/2.8 lens (waiting for the adapters to reverse it). What a sweet lens... Between the EL-Nikkor 5x, and Zeiss 10x and 50x, and a Leitz 20x objective, I think I have the full gamut of magnification covered. Now it's down to working on my technique.
My pictures have improved dramatically in the past couple of weeks, thanks to tips and information provided by members of this forum. There is an amazing depth of knowledge that is freely and cheerfully exchanged on this site. Someday, I hope to be able to provide help to others. In the meantime, I'll mostly be lurking while building stacked images.
Never stop learning!
zzffnn
PostPosted: Wed May 03, 2017 6:17 am    Post subject: Reply with quote
Welcome to the forum, Tim!
Your Zeiss and Leitz objectives are of infinity design, correct? Do you know if they need compensating eyepieces?
With a micro four thirds sensor, you can probably even use a 80mm tube lens, if image cone provided by objective is wide enough. That way, you can turn your infinity 10x objective into a 4x, which would provide better resolution and correction than your El-Nikkor at 5x. 100mm or 125mm tube lens is a safer bet, if you don't need low magnification.
timmymac
PostPosted: Tue May 16, 2017 5:55 am    Post subject: Reply with quote
Well, I meant to reply here, but my reply ended up as a new thread. Sigh... Danged computers!
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Community Members and Friends All times are GMT - 7 Hours
