Green Beetle
Green Beetle
Any chance to get some help with its identification?
(x10 magnification => ~2 mm frame width
Saul wrote:Impressive. Very nice light. Can you share, please, more details about you setup ? Links to the higher res photos ?
Thanks,
Here is my setup:
I used a Nikon CFI plan fluor 10x attached to a Canon EF 70-200mm f/2.8 IS II and an old Canon 500D.
The system is built around a Velbon macro rail with Servocity components. The electronics and the software are adapted from the Fast Stacker, already presented on this forum.
The lighting is made with 4 Ikea Janso Led lights diffused by a foam cup from Walmart.
First photo is made at x10, second one is a vertical panorama made of 4 frames at x7. Each frame had about 450 shots.
The step size was 5 and 7.5 microns.
I don't have a link with high res images.
- MarkSturtevant
The beetle is in the order Carabidae (the 'ground beetles). I don't know more than that. This is a similar species, but not the exact one:
http://bugguide.net/node/view/60633
Mark Sturtevant
Dept. of Still Waters
