www.photomacrography.net :: View topic - Woodlouse - Porcellio spinicornis
iain
PostPosted: Sun Apr 09, 2017 10:43 pm    Post subject: Woodlouse - Porcellio spinicornis Reply with quote
here's a wee woodlouse I found creeping around the garden - a handheld image stack of 37 - 1/125, f5, iso 400. The first and last images are f9
thanks for looking
Iain
Jam35
PostPosted: Mon Apr 10, 2017 1:19 am    Post subject: Re: Woodlouse - Porcellio spinicornis Reply with quote
really interesting shot, because you can see how the insect can just about appear invisible to predators (but not to photographers ) Very Happy thank you for sharing
microman
PostPosted: Mon Apr 10, 2017 6:15 am    Post subject: Reply with quote
Very good photo and good job on the stacking. Handheld is no picnick.
I found a dead one simular to the one in your picture with a parasite stuck to its eye like an alien but i need to clean my sensor before i do any more stacks Sad
PostPosted: Mon Apr 10, 2017 6:37 am    Post subject: Reply with quote
Wow! How did you change the aperture of the camera without moving? That takes incredible body control.
www.loujost.com
iain
PostPosted: Mon Apr 10, 2017 10:39 pm    Post subject: Reply with quote
Yes, it isn't that easy and takes a wee bit of getting used to, but it really improves the transition between focus and out of focus. Previously there was a very distinct line between the two. That said, the trickiest thing is actually remembering to do it at beginning and end of the stack
keks
PostPosted: Tue Apr 11, 2017 10:43 am    Post subject: Reply with quote
It's an interesting technique, I wanna try that too. Just for understanding: wouldn't be the stacked result be the same with all (less) images captured at f9?
iain
PostPosted: Tue Apr 11, 2017 12:31 pm    Post subject: Reply with quote
because I'm handholding and not using flash the resultant shutter speed at f9 is generally way to slow to give results that are much use for anything other than out of focus areas. Also, the sweet spot of the MP-E lens is 5.6 so I aim to get as near to that but still maintain an acceptable shutter speed to minimise camera shake for the main body of the stack. Hope that makes sense...
keks
PostPosted: Tue Apr 11, 2017 12:49 pm    Post subject: Reply with quote
yeah I understand what you mean
MarkSturtevant
PostPosted: Wed Apr 12, 2017 8:47 pm    Post subject: Reply with quote
Very handsome.
Mark Sturtevant
Dept. of Still Waters
