www.photomacrography.net :: View topic - Who tryed Olympus CHC microscope with APS-C body ?
Goto page 1, 2  Next
SWIMMASTER
PostPosted: Sun Apr 09, 2017 7:16 am    Post subject: Who tryed Olympus CHC microscope with APS-C body ? Reply with quote
After buying the Olympus CHC, I try to make pictures with it.
I include 2 pictures, one taken without an oculair, the other taken with the Olympus oculair CWHK10X-T/18L.
Without, I have a light halo, with no halo,
but the resolution of both pictures is very poor.
Should I try to buy the Olympus photo eyepiece FK 2.5x (with adapters) or something else ?
Ichthyophthirius
PostPosted: Sun Apr 09, 2017 9:58 am    Post subject: Reply with quote
It's impossible to say without more information.
- How did you attach the camera to the microscope, in particular, how did you take the image without eyepiece?
- What camera and what camera lens did you use?
- Did you focus the camera to infinity?
- What was the exposure times?
Do you have a camera phone? What kind of image do you get when you simply hold it up to the eyepiece?
Regards, Ichty
SWIMMASTER
PostPosted: Sun Apr 09, 2017 10:52 am    Post subject: Reply with quote
Hallo Ichty,
I attached the camera body Nikon D5100 on the microscope with an adapter that I use when I want to take pictures with my telescope.
It is just a tube that I fixed on the fototube of the microscope, with a little help of tape, just to see what it would give on resolution.
So I didn't use any cameraobjective.
One foto was without microscope-ocular, the other with microcope-oculair: In the fototube of the microscope I put one of the two oculairs, and fixed the camerabody (with no objective) on it by the telescopadapter.
I used 1/160 sec.
I do not have a camera Phone, sorry.
Ichthyophthirius
PostPosted: Sun Apr 09, 2017 12:18 pm    Post subject: Reply with quote
Thanks for providing the details.
This is a complex mix of issues. By adapting the camera the way you did (direct projection and eyepiece projection), you used the optics way outside their design specs. You effectively changed the tube length which, on a microscope, can quickly deteriorate the image.
The tube length on this microscope is 160 mm. This tube length must be maintained for photography. The microscope also requires colour-compensating eyepieces. You can only take photos through the Olympus eyepiece, which does the compensation.
The quick, easy and optically perfect solution to do this is afocal photography, which you may know from telescopes: https://en.wikipedia.org/wiki/Afocal_photography#/media/File:Afocal_photography.png
On a microscope, the eyepiece projects the image at infinity. The human eye, focussed to infinity, picks up the image and projects it onto the retina. To adapt a camera, it has to emulate the human eye. Focus the camera lens to infinity and place it in front of the eyepiece. It will pick up the microscope image and record exactly what the human observer would see.
This approach preserves the tube length and colour correction designed by Olympus.
A step-by-step instruction:
1) Make sure your microscope is set up for Koehler illumination
2) Through the binoculars with Olympus 10x eyepieces: bring your test object into focus, set the condenser and field apertures until your obtain the best image
3) Mount a 50 mm prime lens to your camera. Focus to infinity (view outside the window); then de-activate the autofocus if present. Fully open the camera lens aperture.
4) Mount the camera to a tripod. You need a tripod or something similar, the camera cannot be directly attached to the microscope. Hold the camera with 50 mm lens very close (few mm) in front of one of the eyepieces. Do not scratch the camera lens!
5) Look at the camera image though LiveView. It should already be in focus. If it isn't perfectly in focus, focus again using the microscope fine focus (only minimal movement should be necessary).
6) Does the camera have a histogram function?? Use it to find the exposure level that avoids overexposure. Take photos with a range of exposure times (approx 1/200s, 1/20 s, 1/2s, 2s); for this, you should use ND filters over the illuminator to adjust the light levels; if you don't have any ND filters, regulate the light level on the illuminator itsself (this changes the colour temperature but that doesn't matter at the moment).
7) See what exposure times give you the best images. It's likely that the longer exposures will be better.
SWIMMASTER
PostPosted: Sun Apr 09, 2017 1:50 pm    Post subject: Reply with quote
Hey Ichty, thank you for the detailled explanation.
I did exactly what you said. I tuned the microscope optically.
But I do not have a prime lens, so I used Nikkor 55-300 mm on 55mm F8 1/160 focus on infinity. Camera on a tripod, on 1mm of the top of the x10 oculair, remote control. Here the sensor is not filled, a lot of vignette shows.
Then, I used Nikkor 16-85mm on 50 mm f8 1/160. Here I see even more vignette.
Then I put this lens on 16 mm but it was the same.
Can you explain what you mean bij tubelength of 160 mm? Do you mean the distance from the subject on the glas to the sensor of the camera, using the Olympus oculair x10 ? In my case the distance between the subject on the glas and the top of the Olympus oculair x10 is already 230 mm.
So, now I am going te sleep, in Belgium is it 22.45 hours. Bye
zzffnn
PostPosted: Sun Apr 09, 2017 2:21 pm    Post subject: Reply with quote
You do need a prime lens. Zoom lens used at mid zoom will almost always vignette like that.
As it is now, it is hard to tell whether or not you have successfully set up Kohler illumination. You need to see field iris in sharp focus.
Do exactly what Ichty said, then you will he at 160mm tube length.
L' in the following figure is the 160mm tube length:
http://www.olympus-ims.com/en/microscope/terms/feature11/
PostPosted: Sun Apr 09, 2017 2:28 pm    Post subject: Reply with quote
Vignette is due to inadequate zoom lenses. You can buy for little money a good old manual focus 50mm f1.8 lens that will work very well. With a 10X eyepiece the field will be smaller than through the eyepieces but still convenient (2X relay magnification, less cropped than with the projective FK 2.5X.
Because your camera induces vibrations is very convenient to avoid direct contact with the microscope or you will need to take long exposures (about 2s) or to use electronic flash
For afocal photomicrography take a look at: http://www.photomacrography.net/forum/viewtopic.php?p=99265 and also follow the links inside
Ichthyophthirius
PostPosted: Sun Apr 09, 2017 2:38 pm    Post subject: Reply with quote
160 mm tube length refers to the mechanical tube length (L') of your microscope http://static2.olympus-ims.com/data/Image/IM/OpticalMicroscopes/11_01zu.gif More details here: https://micro.magnet.fsu.edu/primer/anatomy/tubelength.html
All it means for you is that you leave the eyepieces where they are; don't lift them ("eyepiece projection") and don't take them out ("direct projection").
Your images already look good (at the center). The vignetting is due to the use of a zoom lens. Zoom lenses always result in vignetting in this situation because the pupil of zoom objective is deep inside the camera lens.
To avoid this, you need a prime lens. If it is a very flat version (pancake), even better. It doesn't have to be a fast lens and it doesn't need autofocus. All it needs to do is focus to infinity on your camera.
I prefer fully mechanical lenses. I tested the Nikkor AI-S 50/1.8 pancake but it was not good (hotspot). I suspect that the Nikkor 50/1.8 AF and AF-D would work but I haven't tested them: http://www.kenrockwell.com/nikon/5018af.htm http://www.kenrockwell.com/nikon/5018daf.htm You can also test other 50 mm Nikkors. Whichever you can get cheaply and is compatible with your camera.
Regards, Ichty
* Edit: Some triple posting there Very Happy We all agree!
SWIMMASTER
PostPosted: Mon Apr 10, 2017 12:25 am    Post subject: Reply with quote
Thank you all for your advises.
So, I need to get a prime 50 mm as flat as possible, but as I have a APSC-sensor, shouldn't it be better to buy an 35 mm so this will be 52 mm for crop sensors ?
And then, the pictures will be simular in resolution than whith the special photoeyepiece of Olympus FK 2.5x ?
I include two pictures of the size of the microscope. It is impossible to get a tubelength of 160 mm from the objectglas to the top of the occulair. The closest I can reach, by lifting the condensor to the objectglas is 230 with and 200 without an oculair...
So can you explain a little more please ?
Ichthyophthirius
PostPosted: Mon Apr 10, 2017 3:24 am    Post subject: Reply with quote
I may have confused you with the tube length. Don't worry about it any more. When you use afocal, as you do, the 160 mm tube length is maintained. It is measured from the nosepiece to the top of the phototube. On your photo: from the 20 cm mark to the 4 cm mark: 200 - 40 = 160!
The prime lens: 35 or 40 mm would give you a better crop BUT you have normal achromat objectives which are not flat across the whole field of view. This shows even more in the photos. 50 mm is a good compromise.
About chosing afocal or FK2.5x projective: Your choice! The quality should be similar but I haven't tested them side-by-side. Afocal photographs exactly what you see through the eyepieces so the quality should be high.
The suggested combination (10x eyepiece, 50 mm prime lens) give you a magnification factor of 2x (10 x 50/250 = 2); that's less than the FK 2.5x so you will see a larger portion of the field of view in your photos.
The best eyepiece for afocal should be the Olympus WF 10x/BiWF 10x which is part of the Olympus short barrel optical system: Page 13: www.science-info.net/docs/olympus/olympus-micro-optics.pdf
The older WF 10x is not 100% compatible with your newer CWHK 10x eyepieces. You could try to mix them (WF10x in phototube; CWHK 10x in binocular and use the adjustments rings to get everything parfocal, if possible). Or you get a full set of 3 identical eyepieces. Your choice.
SWIMMASTER
PostPosted: Fri Apr 14, 2017 4:55 am    Post subject: Reply with quote
I did some testing with an Nikkor 50 mm 1.4 AI of a friend.
The two pictures are a crop from the whole picture.
For the first picture,
I held the camera (nikon D5100) so close to the microscope oculair, that there was just 1 mm space between the two.
The second picture was taken with 3 cm space between them.
I thought that the 3 cm space should blur the image, but this was not really the case.
So I do not think that coming closer will give a sharper image ???
Should the Nikkor 50 mm 1.8 AI be a better choise ? There is also a long nose version.
The Olympus eyepiece FK 2.5 isn't easy to find.
PostPosted: Fri Apr 14, 2017 7:40 am    Post subject: Reply with quote
Not really, be aware that the eyepiece at its right focused position produces a virtual image at infinite and the camera lens is focused to infinite to capture it, so in this sense distance doesn't matter, it could matter about vignetting and in some cases about using the periphery of the lens, often not so well corrected than the center. A position between both cases could be the adequate (easier centering than with 3cm and less chance of damaging the lens than with 1mm)
The 1.8 lens will do the same. The advantages are that it is cheaper, lighter and shorter (could be less prone to vignette with some low eyepoint eyepieces).
Your image could be sharper if you avoid vibrations, use low ISO setting and likely if you set the condenser and its diaphragm at the optimal position
Ichthyophthirius
PostPosted: Fri Apr 14, 2017 11:00 am    Post subject: Reply with quote
As Pau said, there will be vignetting at some point when you away far enough. There is actually an ideal distance between the exit pupil for the eyepiece and the entry pupil of the camera objective. In practice, most people just mount the lenses very close together (few mm) and it will work.
The afocal adaptation uses only a very small central area of the camera lens (= the f-number is very high). So f1.4 or f1.8 makes no difference as such. The lens design matters and it's more important that you have no hotspots. Test all the magnifications, especially the 100:1 objective. It you have found one that works for you, keep it. Make sure there is no dust in the central lens area as dust would show on all your images!
The crops you showed look OK. The red blood cells in the blood vessel are sharp. There seems to be no motion blur. To make sure, you need to compare different exposure times.
It is not useful to look at 100% crops on a microphotograph; they always look bad because of empty magnification. Could you please also post an image of the whole frame (with information on the objective)?
Regards, Ichty
SWIMMASTER
PostPosted: Sat Apr 15, 2017 1:09 am    Post subject: Reply with quote
This was taken with an old Nikkor 50 mm AI 1.4 focus infinite F2.8.
The microscope objective is HI x10
I wonder if the Olympus eyepiece FK x2.5 would be much better ?
Ichthyophthirius
PostPosted: Sat Apr 15, 2017 5:34 am    Post subject: Reply with quote
The photo looks OK. There is sharp detail even around the edges. The corners are not sharp but that is to be expected with non-plan objectives. Lighting is OK as well.
See if it improves when you do a 2s exposure.
There are two issues that could be percieved as problems:
- your histological section is not completely flat so not all the detail is within focus
- the camera picks up on out-of-focus detail much more than the human eye so it looks worse than though the eyepieces
Sample preparation is the most important factor in microscopy, much more important than the optics or the camera gear. It will take you some time to master the techniques. If you want to improve your camera set-up further, you should also use a stage micrometer as a test object.
Regards, Ichty
Goto page 1, 2  Next
Page 1 of 2
