www.photomacrography.net :: View topic - New Here- Simple Rig Question
timothyjw
PostPosted: Tue Apr 04, 2017 8:55 am    Post subject: New Here- Simple Rig Question Reply with quote
Hello all,
My name is Tim. I've been creeping on this forum for about a year or so and I finally decided to join. I've done some poking around on here in attempts to understand all of the terminology.
For the last few years I've been shooting anywhere from 1:1 to 3:1 and I wanted to play with higher magnifications. I've done lens reversing and stacking in the past. I found a helpful thread for users looking to dip into this type of shooting but I figured I'd ask a few questions myself.
I currently shoot with a full frame Nikon D610. I'm looking for a simple, high magnification rig and I came across three components I might need to achieve this. How does a
1. Nikon 200mm F4 AIS, with a 2. Nikon 10X Plan Achromat infinity objective on a 3. Nikon CFI M25 microscope objective M52 52mm adapter sound?
Will I run into any vignetting issues? Will I be satisfied with the results of this setup? Cost isn't a huge issue right now, I just want to do this the right way.
Thanks- and thanks for having me!
-Tim
PostPosted: Tue Apr 04, 2017 3:11 pm    Post subject: Reply with quote
Welcome Tim
Sounds like you're getting well set up.
Which objective is it? The "brown" one?
Your corners won't be as good as the middle, but if often doesn't matter.
Assuming you're stacking, the focus increments, lighting and vibration will be bigger issues that the objective, for quite a while. Apart from the subject.. Wink
timothyjw
PostPosted: Tue Apr 04, 2017 4:31 pm    Post subject: Reply with quote
ChrisR wrote:
Welcome Tim
Thanks, Chris!
I believe it is the brown one.. it is brown in color at least. Here is the link I plan to purchase from. http://www.seoenterprises.com/shop/product.php?productid=16268
I do plan on using it for stacking, and I'm sure it'll be a task to control all of these different variables. I appreciate your help! I remember getting nasty vignetting or light leaking when stacking lenses, and I wasn't sure how bad this might look on full frame. I assume the 200mm F4 is set to infinity at all times and it's a matter of moving back and forth on a rail for the stacking?
This is a stupid question, but why doesn't the adapter itself affect the image if you're blocking off most of the end of the 200mm lens? The image becomes only what is seen through the objective?
Thanks!
