www.photomacrography.net :: View topic - Is this microscope good for starting microphotography?
SWIMMASTER
PostPosted: Mon Apr 03, 2017 12:02 am    Post subject: Is this microscope good for starting microphotography? Reply with quote
Hello everybody,
I am very impressed with what you show on this platform.
Being a macrofotographer for some years now, I would like to try some microscope photography. I find someone who wants to sell his Olympus-microscope for 200 euro's. (Two 10x-T/18L oculairs, WF 101 on the camera tube, HI 100, 40, 10, 10(0,25) , 4) Can anyone with experience give me advise on this matter ? I wonder if it would be difficult to connect my Nikon D5100 body, and should I need a certain lens that fits in the connectingtube ?
You see, a lot of beginners questions...
Ichthyophthirius
PostPosted: Mon Apr 03, 2017 5:57 am    Post subject: Reply with quote
This is an Olympus CH microscope http://www.alanwood.net/photography/olympus/downloads.html#ch with trinocular head and Koehler illumination light source. IF everything is in good condition, that's a good offer.
Its a small, simple stand but it has almost all you need:
- trinocular head
- proper stage
- field aperture
The objectives are Olympus short barrel achromats; they are OK for starting work. Later you might want to upgrade to plan objectives, for example the Olympus LB (long barrel) objectives, which should also fit on this microscope. This is something you should test; use an objective with 45 mm parfocal length (= LB) and see if the condenser and light source still fit underneath the stage.
The Olympus 10x-T/18L oculars are actually part of the LB optical system.
You can't mount the camera directly to your microscope because the Nikon DSLR has vibration isssues: http://www.photomacrography.net/forum/viewtopic.php?p=84940 You have to put an Olympus compensating eyepiece into the phototube and mount the Nikon camera above the phototube using a tripod or copy stand ("afocal adaptation").
Ususally, a widefield, compensating, high eyepoint eyepiece 10x is combined with a 40mm to 50 mm prime lens on your camera.
Possible upgrades:
- new set of objectives
- replacing the lamp in the Koehler illuminator with an LED
When testing the microscope make sure that the main and fine focus gear are in good working order (no cracking, slipping etc.)
Regards, Ichty
zzffnn
PostPosted: Mon Apr 03, 2017 6:48 am    Post subject: Reply with quote
To add to what Ichty has said about afocal imaging:
You can also use long exposure or flash to reduce vibration. For example, use a right angle prism under condenser to direct flash up , while keeping some scope light for focusing.
SWIMMASTER
PostPosted: Thu Apr 06, 2017 7:56 am    Post subject: Reply with quote
I bought this microscope, I did the controlls that Ichty mentioned, all the gear goes smoothly, no cracking ....
The objectives x10 and x 40 are very clear. Only the x100 is too soft. I think that it has to be cleaned, but it has such a small opening, I do not know how to clean this.....?
Without an photo eyepiece, I could make some pictures, but they are not as sharp as what I see through the oculairs.
So I searched equipment for connecting my Nikon D5100 APSC-body on this microscope with a phototube diameter 25 mm(more or less).
But this is not very clear for me.
I have a kind of lens adapter (see picture) to connect my camera on a telescope, and I hope I can use this also for connecting my microscope.
I think I need the photo eyepiece FK 2.5x
the eyepiece adapter PM-ADF
An adapter L (there are several...)
And hope I can use the lens adapter I have.
I am now confused, and don't know anything for sure....
Any suggestions would be welcome.
PostPosted: Thu Apr 06, 2017 8:33 am    Post subject: Reply with quote
The 100x question is easy - it's an objective designed for Oil Immersion.
You should get a poor image without the oil Smile
zzffnn
PostPosted: Thu Apr 06, 2017 8:40 am    Post subject: Reply with quote
If the 100x oil objective does not image well with oil and looks to have a dirty top lens, then it may have dry oil on its top lens. You can simply use a high concentration alcohol to wipe it off (most of the time, it will come off). If not, you may try acetone (less harsh) and Xylene (harsh). But only let acetone or xylene stay on lens for a few seconds, they may separate yours lenses if they stay too long. To be safe, ask Alan Wood what cleaning agent Olympus recommends for their oil objectives.
You may use lens step-down (or step up) rings connection a photo eyepiece to your camera body (or camera lens), if you want a solid (not suspended/air gapped) connection. The eyepiece may have removable shells that you can remove to help connecting to lens rings and you may carefully use super glue. But I think it is best to separate camera from scope by air gap (support camera on copy stand of tripod).
PostPosted: Thu Apr 06, 2017 9:03 am    Post subject: Reply with quote
Be aware that it's an oil immersion objective, are you?. Without oil it will produce a very poor image, some models aren't unable to form an image at all.
BTW you need to put a drop of an oil specifically oil intended for immersion microscopy.
This kind of objectives are designed to be easily cleaned as after use they need to be cleaned to remove oil, you need an oil solvent that does not let residues like xylene or absolute ethanol*. Apply it in very small quantity by means of lens cleaning paper or a cotton swap. It's important to check the result with a stereo microscope or a loupe (a reversed eyepiece used inverted close to the eye is a very good one)
* some makers like Zeiss do not recommend ethanol
For photo you also have other options:
- an old style camera adapter like the Pentax. I can work both with the FK or with a 10X slightly raised:
http://www.ebay.com/itm/Honeywell-Pentax-Asahi-Microscope-Adapter-Box-Instructions-/262888685304?hash=item3d3562fef8:g:SqwAAOSw4CFYtMQH#shpCntId
- Afocal: http://www.photomacrography.net/forum/viewtopic.php?p=99265
Ichthyophthirius
PostPosted: Thu Apr 06, 2017 1:34 pm    Post subject: Reply with quote
As the others have said, you need a bit of immersion oil (n = 1.515-1.518). For cleaning, I recommend following these instructions: http://microscopy.duke.edu/downloads/The%20Clean%20Microscsope.pdf
Leitz and Zeiss recommended either Xylene or 'petroleum ether'/isopropanol for cleaning. Both companies warned against using ethanol on their old (pre 1990s) optics (this should also apply to your Olympus objectives). Never use acetone, ether, etc.
As for your camera, as I said, you can't attach it directly to your microscope (please see the references I linked). Unless all your exposures are > 1 second (unlikely?). That is the case for most Nikon DSLRs. So there is no use for adapter L and so on. Your camera needs to be mounted on a tripod or copy stand, without direct connection to the microscope.
Then you have two choices:
Projective: FK 2.5x is the one matching your Olympus objectives. Put it in the phototube and mount the camera with sensor about 150 mm above the projective. Protect the camera sensor by putting a camera UV filter across the front (e.g. Nikon-M42 adapter; 42-52 step-up adapter; 52 mm UV filter). Many users find the field of view with a projective 2.5x and APS-C sensor too small!
http://www.alanwood.net/photography/olympus/photo-eyepieces.html#fk
Afocal: Olympus 10x compensating high eyepoint eyepiece + 50 mm prime lens! That's all you need.
Take one of your 10x/18 eyepieces and put it in the phototube. Put a 50 mm prime lens on your Nikon and focus to infinity. Just hold your camera over the eyepiece and take some pictures, taking care that you don't scratch the front lens. Are the images any good?
Regards, Ichty
P.S.: Here is more information about your objectives: www.alanwood.net/downloads/olympus-micro-optics.pdf
SWIMMASTER
PostPosted: Fri Apr 07, 2017 12:32 am    Post subject: Reply with quote
Thank you Pau, of course I didn't know that I had to use immersion oil, but I am learning.
But to clean the front of that x100 objective, I do not understand how.
The opening is not 1 mm in diameter, how can I reach the front of the lens ? Looking through an other oculair, I see that the front lens is covered with oil residus. So cleaning will be needed.
Must I open it ? Or must I use a soft wooden toothstick (with Xylene or petroleum ether/isopropanol) and stick it through the frontopening trying to wipe the dryed oil off ?
SWIMMASTER
PostPosted: Fri Apr 07, 2017 12:42 am    Post subject: Reply with quote
I also read somewhere, that in stead of oil, I could use distilled water, (waterimmersion), so I don't have to clean it after using....
I wonder, is this also the case with this x100 1.30 objective, or is this only for objectives specially made for waterimmersion ?
I have so many questions, I am Lucky that there are so many helpfull people in this forum, thank you all, I need your advise .... Rolling Eyes
Ichthyophthirius
PostPosted: Fri Apr 07, 2017 3:11 am    Post subject: Reply with quote
Quote:
Must I open it ?
Never!
Please have a look at the link I sent; http://bio.sabanciuniv.edu/sites/bio.sabanciuniv.edu/files/general_clean_microscope-1.pdf
It is very detailed. Please invest some time to read through it. It's worth doing so you don't do any permanent damage.
Regards, Ichty
zzffnn
PostPosted: Fri Apr 07, 2017 4:55 am    Post subject: Reply with quote
No, in general, you cannot use oil objectives with water immersion, or water objectives with oil immersion.
To clean dried oil residue, you don't have to stare at the top lens, just wipe its approximate location with the correct cleaning agent.
Ichthyophthirius
PostPosted: Fri Apr 07, 2017 5:22 am    Post subject: Reply with quote
BTW, a great technique to clean FRESH immersion oil is shown here:
https://micro.magnet.fsu.edu/primer/anatomy/cleaning/cleaningfigure9.jpg
- Wear goves (not shown Wink )
- Put the objective on a table, front lens facing up
- Put one small drop of xylene on a Whatman lens cleaning tissue
- Gently move the issue across the front lens once, holding the lens paper; the oil is taken up by the paper
- Throw away the paper (single use)
This is very gentle, applies minimum pressure from the top and the thin film of xylene cannot run into the inside of the objective.
