Diatom Threw Slide Mix
Hello,
her are some pics from a recent threw slide set.
All credits for the slides go to Anne.
All images were taken with the Olympus SPlan Apo 60x/1.4, green filtration, NFK 3.3x and Nikon D800, processing in RawTherapee, stacked in Zerene and polished in Photoshop.
1:
Pinnularia neomajor, ~170µm
Areolae, crop from the image above, pore distance between 170 - 190nm
Rhopalodia spec., ~180µm
Crop from the image above
A mandala
And a really small one
Thanks for looking,
Michael
1:
A mandala
Thanks for looking,
Michael
Thanks for your answers!
It's not really "plain" transmitted light. A little bit oblique, and I was playing with the crossed polarizers to achieve maximum detail/contrast. If you don't mind ending up with monochrome images, green light is better in terms of flaring and resolution than just using the green channel of a "white" light image. Due to interference effects, other wavelengths also tend to creep into the green channel, so the result with white light is usually a bit inferior, depends on the circumstances. For max resolution, it would be best to use 365 nm UV light and a modded DSLR and according filtration.
Best regards,
Michael
Best regards,
Michael
- carlos.uruguay
- Cactusdave
Thanks again for your comments,
here are another two:
Cymatopleura elliptica var hibernica (W. Smith) Van Heurck 1896
Diploneis alpina Meister
Thanks for looking!
Best regards,
Michael
Edit: Thanks to the help of the diatom-experts on the german microscopy-forum, i was able to add the identification
Thanks for looking!
Best regards,
Michael
