www.photomacrography.net :: View topic - Quick Tips for beginners?
Vilijam
PostPosted: Sun Mar 26, 2017 4:36 pm    Post subject: Quick Tips for beginners? Reply with quote
Hello!
nice to meet you guys ... nice and competent community out here Smile.
As I have just started to dig into Macro photography, I was looking for an advise where to start with my researches. Some kind of "Quick guide for dummies" - post?
Maybe someone would be so nice and guide me into the right direction?
I am shooting on a Canon 5DSR + MP65 lens. Recently I bought an automated micro-rail with controller. For stacking I use Helicon Focus and Lightroom / Photoshop for cleaning and adjustments.
but ...
... how can I prevent this "blur" around objects which are in significantly different layers? I have heard that Helicon has more problems than other programs ... is this evtl. the reason?
Looking at the image of my hornet, there is significant blur around the "antenna" ... any idea?
... I was shooting at f8 ... does anyone have experience with the sweet spot of this lens?
... how much overlapping should I consider when calculating step size and DoF ... is "the smaller steps the better" a good approach for reaching top quality - or is there a "too much"?
I appreciate your help, TIA.
Vilijam
Get closer.
Vilijam
Vilijam
PostPosted: Mon Mar 27, 2017 6:10 am    Post subject: Re: Quick Tips for beginners? Reply with quote
I have found Zerene Stacker Info, which is already a good starting point I guess ... thx!
Get closer.
Vilijam
PostPosted: Mon Mar 27, 2017 7:54 am    Post subject: Reply with quote
Hi And welcome!
Yes, there's no single guide, though the one you found gets you going.
The blurred out-of-focus stuff is a problem. Lighting make it worse or better, but there aren't really any golden rules. Member Beatsy found he had a good result but doesn't know why, recently!
It sounds like you're on your way.
Yes f/8 is good for the MPE, going wider at more than 2x. I use 5.6 or 4 mostly.
PostPosted: Mon Mar 27, 2017 2:10 pm    Post subject: Reply with quote
Quote:
but ...
When you have solid objects at significantly different planes this will always be a problem. The sensor never clearly "sees" the background area adjacent to the foreground (antenna, leg, etc). This is because as the stacking moves toward the background layer, the foreground object goes out of focus and "enlarges" blocking the camera view. In stacking software the contrast methods (PMax in Zerene and "Method C" in Helicon) are far better at minimizing this effect than the other stacking methods. But is is unavoidable to as certain extent. A smaller shooting aperture can help somewhat... but make it too small and you start to lose resolution due to diffraction. This is one key reason that most stacks of this type will need some "Photoshop" work to really clean up some inevitable "artifacts" of the image stacking.
Vilijam
PostPosted: Mon Mar 27, 2017 4:06 pm    Post subject: Reply with quote
Thanks for your input, I will consider that throughout my trials!
Get closer.
Vilijam
Vilijam
PostPosted: Mon Mar 27, 2017 4:41 pm    Post subject: Reply with quote
Charles Krebs wrote:
Quote:
but ...
Thank you for the explanation - that makes sense.
I´ll try to play with the parameters in Helicon, but I understand that this phenomenon can not be resolved simply by SW due to overlapping of large "Circles of Confusion" with the "sharp" points in focus at that moment.
So, ok - I have to shoot just flat insects without legs and tentacles or so.
Although Photoshop really seems to be the most rational approach, in parallel I am also trying Zerene in all kind of modes to get a feeling for the differences and possibilities. If I stumble over something interesting, I will let you guys know.
Thanks again for your inputs!
Get closer.
Vilijam
GrayPlayer
PostPosted: Thu Aug 31, 2017 6:03 pm    Post subject: Reply with quote
Would shooting from "back to front" help?
Fred H.
PostPosted: Thu Aug 31, 2017 6:54 pm    Post subject: Reply with quote
No. Stacking software ends up doing the same thing regardless of which way you shoot the stack. Forcing the order can affect framing, for example whether the edges get cropped, but it won't have any effect on halos.
